Question about Dryers
Marvin whirlcool system fan dropped on floor off chair. Fan blade broke off. Now wobbles. Can I order a new fan blade and fix myself or do I need a new fan?
I'm looking for parts for a Marvin fan model 1220
Fixya doesn't have any way to provide parts for any product. We can provide assistance to install it but the part itself. Sorry
Jul 02, 2012 | Marvin Dryers
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
I have a Marvin 1210 window fan with a rotating front grill. The grill has come unscrewed from the fan motor shaft and I can not see how to take the front nose cone apart to get to the screw so I can...
mcdevito75 here, hello ken, I did a fast search and I think www. shop.com can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Jul 23, 2010 | Marvin 1210 Floor / Box Fan
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
Heater fan noise
trw www.sears.com the parts dept...have make and model ready!
Dec 10, 2008 | Marvin 2060 Compact Heater
Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Jul 03, 2008 | Marvin 1210 Floor / Box Fan
Fan blades
their is problem in push! change your fan push! then the wings are rotate
Jun 29, 2008 | Marvin 1210 Floor / Box Fan
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Marvin quartz heater
Do they have a fan in them. If they do then the noise maybe coming from a bent fan blade. If you are mecahanically inclined then I would go into it and see. That would be the only moving part in the thing other than the tip over thing inside. I hope this helps
Jan 26, 2008 | Marvin 2060 Compact Heater
Dryers Logo
113 people viewed this question
Top Dryers Experts
