Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
My oxygen will not pick up pet hair out of the. The brush rotates
My oxygen will not pick up pet hair out of the carpet.
    Problem Solver:
  • 10 Answers
Cheak belt
Posted on May 13, 2010
2 Suggested Answers
SOURCE: My oxygen will not pick up pet hair out of the. The brush rotates
Your brush may not be spinning try pressing the reset button on the back of the power nozzle, it that does not work you may need to change the belt.
Bob
eVacuumStore.com
Posted on Mar 27, 2010
How do I know which way round the carpet control works on power vx pet
I don't have one of these but normally the hard floor surface will have a brush around an edge or all the way around in contact with the floor, and for carpet you will just have the normal rotating brush. The rotating brush is always there.
Oct 16, 2014 | Vax U89-P9-P Power 9 Pet Bagless Upright...
Dc41animal leaves obvious tracks on beige carpet
Hi Alan, it's Jack at Dyson.
Like all Dyson upright vacuums, DC41 Animal includes a motor-driven rotating brush bar. This includes stiff nylon bristle tufts which sweep into the carpet pile, agitating out dust, grit and stubborn pet hair. This will also have the effect of raising the carpet pile where it's been trodden down from daily use - this is what causes the tracks you've noticed. You can see how DC41's brush bar and cleaner head are engineered to work in the video I've attached.
It is possible to turn off the brush bar using the silver brush control switch next to the red on/off switch. However, the brush bar is an important factor in effective carpet cleaning and we would always recommend vacuuming carpets with the brush bar turned on - with the exception of delicate carpets or rugs.
It does sound like your machine is working correctly, in the way it was designed. I hope this information is useful to you, but if you would like some further advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 09, 2013 | Dyson DC25 All Floors Bagless Upright...
When I vacuum, I get 1" wide stripes where the
Inspect the brush.
Turn on the vacuum, CAREFULLY pivot the machine so the front goes up and the rear wheels stay on the ground. Is the brush rotating.
If not, inspect the belt after turning the vacuum off and unplugging.
It they are rotating, inspect the brush with the machine off and unplugged. Are there high & low spots?
Gary
Jul 11, 2011 | Bissell Upright Vacuum - The Pet Hair...
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Brush not rotating on dc 24, filters cleaned.
carpet threads and pet hair?
check and clean the roller brushes - if they are clean you may need a belt.
Mar 29, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Bob
eVacuumStore.com
Mar 18, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My Bissell Pet Eraser brush only rotating on the bare floor setting, when on the pet setting, it won't rotate. What is the problem? Thanks.
it sounds like something is backwards. the brush should only rotate when using it on carpet, it should never rotate on the bare floors. check the belt for propper installation
Jan 03, 2010 | Bissell Upright Vacuum - The Pet Hair...
I have a Lift Off Pet Bagless upright and ever since I **** up a hair tie it hasn't been **** up the dog hair from my carpet. I have gotten the hair tie out of the vacuum but it is still not **** up.
One of the reasons it might not be picking up is because you have a worn belt. The other reason could be that the suction channel is clogged. Did you remove the hair tie you ****up? If you need a replacement belt you can get it here: Bissell Lift-Off Pet Replacement Belt
Oct 30, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Pet Hair Eraser Vacuum marking carpet
the brush is always turning on the machine even when your using the tools. try not to set it down on thick carpet , or if you can set it on the linoleum.
Sep 16, 2009 | Bissell Upright Vacuum - The Pet Hair...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
76 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
