Question about Kodak EASYSHARE 5100 All-In-One Printer
You can barely read anything that is printed from my Kodak 5100 printer. I have replaced both the color and black ink cartridges. What do I try now?
  • 64 Answers
Printhead clean, done from the maintenance on the printers software. Also if that doesnt help, contact the printer manufacturer for a replacement printhead.
Posted on May 13, 2010
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
I own the 533 series Kodak printer and purchased
make sure you but the ink as it sould have and check the ink to see it has ink or color?
Jan 10, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Check color ink always blinks and does not allow to do any job.
Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 Needs Both Cartridges To Print?
Unfortunately, you cannot used the printer if one of the ink cartridge is empty., compare to the other printers you can print a black text or gray scale if the color is empty or one of the cartridge is empty.
All kodak printers work the same both cartridges should have ink on ink before you can use It.
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Kodak Easyshare 5300 Will not print black ink
They overnighted a new printer head and free ink. We already recieved it. AMAZING. Thank you Kodak. They are awesome.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Black ink non-printing
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
113 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
