First - re-seat the hard
disk and reboot the computer. If the computer does not boot up then reboot and
go into the BIOS configuration to see if the BIOS detects the hard drive. If it
doesn't detect the hard drive then it could be faulty.
Then the hard drive needs
to be replaced in the computer/laptop, Windows installed and the computer or
laptop's device drivers plus your programs etc. to get a functioning
computer/laptop again.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Hard drives do not like being dropped even inside a notebook. It is a sure way of destroying a hard disk. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
The hard disk could be faulty, they do not like being dropped. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Solution 3 1.Remove theharddrive 2.Plugjumperon the harddrive 3.Plugthe harddrive,then turn on yourlaptop
Solution 4 1.Remove theharddrive,plug theexternal cable. 2.Connectthe harddriveto another computer,withUSBconnection 3.If the harddrive can bedetected,ejectthe harddrive 4.Plugthe harddriveto the laptop,then turn on Intended to makethe harddrive canworkwith thehelp ofanother computer
Solution 5 1.Remove thelaptop hard drive 2.Plugthe laptop hard driveto my PC. SATA1-PC hard drive SATA2-Laptopharddrive 3.Bootthe computer froma PCharddrive The purpose of usinga PCcomputermain-boardasdrivers ofthe laptop hard drive.
I hope this information helps. Thank you for using FixYa!
The notebook cannot detect the hard disk when you turn on the notebook.
Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.
Your computer must have dropped or was bumped just right to knock out the hard drive, your hard drive is located on the bottom of the laptop. Depending on which laptop you have you should have 2 screws located on a panel.You will want to take off the panel and push the hard drive back into the slot. Keep in mind it you have a warranty on your laptop you may want to consult the Manufacture first.Good Luck
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
