I forgot the administrator password for my acer laptop, and now I can't log on to my laptop. How can I get through the administrator password so that I can reset it????
ADMINISTRATOR PASSWARD CAN BE RECOVERED THRU THIRD PARTY SOFTWARE, IT RESETS THE SAM FILE AND ALLOWS YOU TO BOOT WITHOUT PASSWARD AND LATER U CAN SET THE NEW PASSWARD....CONTACT ME AT msuhelk@yahoo.co.in
Recover the password using a PASSORD RECOVERY TOOL. Password recovery tools are software programs that work by making super-fast guess after super-fast guess until the password is discovered. They're a little hard to use at times but are very effective. Example:OPHCRACK, CAIN & ABEL, LCP, JOHN THE RIPPER.
Perform a clean installation. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
when i right click on the yahoo messenger icon, i left click on the 'open' option. Nothing happens....
(More)
when i right click on the yahoo messenger icon, i left click on the 'open' option. Nothing happens. Yahoo messenger will not open. Do you know why this is? When this happened initially, I deleted the programme from my computer. I then downloaded the newer version but still nothing happened when i tried to open yahoo messenger. I then rebooted the laptop and tried to open yahoo messenger version 10 again, but it still did not open.
Sony VGN-A790, 17? 1920x1200, ATI 600x (256MB) screen went dark when I connected a digital external...
(More)
Sony VGN-A790, 17? 1920x1200, ATI 600x (256MB) screen went dark when I connected a digital external monitor, worked fine with an analog. Any external monitor works. primary is so dark it looks blank unless you look at an angle. Occasionally it blinks with normal contrast then goes dark again. ati had a brief web note stating connecting a digital monitor & screen going blank was a known problem without solution. tried everything except reformatting the hard drive. could this be mechanical or voltage problem? Changing graphic cards? I hate to toss a 1920x1200 17?
I have a custom laptop built by ''I Buy Power'' I have been searching for a way to update the BIOS....
(More)
I have a custom laptop built by ''I Buy Power'' I have been searching for a way to update the BIOS. Windows and the BIOS is reporting the cpu speed as 800Mhz (never any higher)it is an AMD athlon 64 3400+ capable of 2.2Ghz. The mother board is a ''Hannstar J MV-4 94V-0 0443'' (all I could find written on it) it has an AMI BIOS ver 08.00.11 and an SiS chip set. The numbers at startup are ''63-0100-000001-00101111-090604-sis755-258ka000-y2kc'' Please if you can help me find a BIOS update or another fix to get the cpu to run correctly I would be VERY grateful.
I am not getting an output from the s video port on this laptop.Is it possible to reset the video...
(More)
I am not getting an output from the s video port on this laptop.Is it possible to reset the video card?It hasn't worked since i shut the power down. The laptop works fine,but i do not get an output.
