InFocus LP 600 Multimedia Projector Logo
A
Anonymous Posted on May 11, 2010
The InFocus LP600 won't power up - InFocus LP 600 Multimedia Projector
Anonymous
Level 2:
Champion:
  • Expert 269 Answers
  • Posted on May 19, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
269
Questions
Helped
105505
Points
416
Make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
3 Related Answers
Anonymous
  • 26 Answers
  • Posted on Feb 28, 2008
SOURCE: InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Anonymous
  • 563 Answers
  • Posted on Apr 11, 2008
SOURCE: espejo interno roto infocus lp600
English ?
projdoc
jasbo
  • 2239 Answers
  • Posted on Mar 18, 2010
SOURCE: the InFocus LP600 won't power up
power supply. this model has a problem with them.
I am looking online for a Service Manual to download for the Infocus LP600 projector Can you direct me to where one may be available?
you won't be able to get one for free. infocus service centers are prohibited from releasing that info. if you want a user's manual, try www.projectorcentral.com
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Tunel de luz
Last time I checked, the light tunnel was available. It is a special order and cost $52.80 plus shipping.
Infocus has discontinued parts for a number of their projectors. If it is still available, it could take as long as 4 weeks.
InFocus LP600
Yo
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Power point conectivity
PowerPoint is a computer program. It has to be running on a PC for it to connect to a projector.
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
