Question about Tayama TRC-10 Rice Cooker
Cook button doesnt stay down
Our rice cooker worked perfectly for several months and now when you press cook it doesn't say down.there are lights.
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: WHERE CAN I GET THE
Hi and welcome to FixYa, I am Kelly.
I do not have the wiring diagram but... the 2 wires that go to the top of the unit fray and break at the lid hinge point and cause this problem quite often. The 2 wires in the hinge area are for the upper temp sensor. (The floating plate in the top of the lid) If you fix the wires in the hinge area most of the time the come back to life unless the heating element has failed. The heating element will read about 180 Ohms resistance if it is good. The resistance changes a bit as the unit ages.
Try fixing the wires in the hinge then testing the cook button. I usually have extend the wires in the hinge and do a double splice for the NEW wire strip on each wire with heat shrink tubing over the repair.
If this does not work just respond here and I will assist you further.
Thanks for choosing FixYa,
Kelly
Posted on Jan 28, 2011
My rice cooker doesn't turn on cook while i pushed button down
First of all check if the power socket works by using another electric tool, the rice cookers have an extra on/off button somewhere in the back, others dont work if the head is not properly close. If any of that doesnt wprk, unless you have some experience in electrics i recommend you to buy a new one or to bring it to professional. Good luck and stay safe ;)
Oct 17, 2016 | Kitchen Appliances - Others
I have s Sanyo ECJ-S35S rice cooker does not heat up. When I press Start/Cook button it keep flashing and light does not stay on. Any idea what I can do?
A rice cooker that doesn't cook anymore usually requires a thermal cutoff replaced. They act like a fuse and look like a resister. Look underneath it is crimped to one of the leads but perhaps underneath some braided insulation. Purchase another cutoff at an electronics components store (not radioshack). If there is not a rating on it try 185 degrees celcius.
Sep 22, 2013 | Sanyo ECJ-S35 3.5-Cup Rice Cooker
Completely stopped working. Plugged it in and the lights wont come on and it doesnt cook rice. Had it maybe right at a year.
Had mine 3 months and mine has done the same thing THREE times. ...with THREE different cookers!
Jun 10, 2011 | Rival RC61 6-Cup Rice Cooker
Aroma rice cooker ARC 978 - all control panel lights stay on when pluggged in. How do I reset??
Unplug the rice cooker and the remove the cooker kettle. Push the steel button in the center of the rice cooker to loosen the spring. Plug the rice cooker without the kettle, the cook function must not be functioning. Plug it again with the kettle and push the cook switch to see if it working properly.
Nov 08, 2010 | Aroma ARC7031G 6Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Tiger rice cooker (model JAT-A55U): Rice is not completely cooked
This one has several options to cook different types of rice, white rice, brown rice, sweet rice.... Press the menu to see the correct setting you need for what type of rice you are cooking before pressing the cook button.
Sep 02, 2009 | Tiger JAT-A55U 3-Cup Rice Cooker
I purchased today, when i tried to cook rice, followed directions, cook light only stayed on 10 minutes and warm light automatically turned on. Rice and water were cold. I tried several times and reread...
This a bad unit. You sould return for an exchange. There is thermo strip inside to control cooking time and to change the stage of ON/WARM light when it reaches the calibration point depending on the weight of rice to cook. Now it is not working.
Aug 12, 2009 | Rival RC61 6-Cup Rice Cooker
MY RD5081 RICE COOKER ONLY WILL JUST WARM RICE, WON'T COOK.
The preassure switch may be not working right.
It may be corroded, etc.
Unplug the unit and push it back several times, try to see if the spring is working, etc.
Apr 02, 2009 | Hitachi RD5086P 8.3-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
Rice burning at bottom of cooker
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Aug 30, 2007 | Oster 4724 Rice Cooker
Tayama TRC-10 Rice Cooker Logo
Top Tayama Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Tayama Kitchen Appliances - Other Expert? Answer questions, earn points and help others
