Question about Miele W304 Front Load Washer
Heater element appears to be faulty. How can I gain access to test it ?
4 Suggested Answers
  • 209 Answers
SOURCE: Heating element Zanussi washing machine
remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Posted on Oct 07, 2007
barkencoa
  • 3463 Answers
SOURCE: Zanussi FJD1666W heater removal.
There is no easy way to access the heater without stripping it down.
Remove top cover.
Remove 2 scews at rear bottom of cabinet.
Remove 2 plastic covers at front bottom sides of cabinet, and remove 2 screws located in holes, you will need a nut socket to remove them.
Remove inlet hoses, and undo screw at top where the hoses connect to, prize up the plastic retainer that holds the valves in place.
Remove screws at top of cabinet that hold the 2 halves together.
Then lift rear half of cabinet clear of the front.
At the bottom rear you will see the heater element located.
Undo center nut and remove element..
Fit back all parts in reverse order.
Not an easy job. Good luck.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 389 Answers
SOURCE: nType your problem for a solution...need to access the heater element to test
not to familier with your washer but you have to take the back off and then you should see the heater at the bottom of the drum with wires on take the wires off make sure you mark them get a muti meter set it on ohms test across the two terminals you should get a reading if not the heater has gone and try it from one terminal to earth on cabinet you should not get a reading if you do its faulty
Posted on Dec 01, 2011
HE error code on samsung dishwasher?
This is usually a failed HEATING ELEMENT or HEATER RELAY. Disconnect power & remove the dishwasher from under the counter.
The HEATER RELAY is located on the right side of the D/W. A metal panel/shield (on the right side) must be removed to gain access for testing.
Testing the HEATING ELEMENT *can* be done from the bottom/front---but is easier if the D/W is placed on it's back---and removing the bottom cover/panel.
In many cases I have seen failed HEATING ELEMENTS or RELAYS on Samsung D/Ws---in homes which had an INSTANT WATER HEATER (AKA: Tankless Water Heater).
This type of Water Heater requires a minimum GALLON-PER-MINUTE of water flow---before it will *heat* the water.
Many dishwashers have a lower GPM flow rate than required---this results in NO HOT WATER at all during water fill.
The D/W heating sytem remains "on" for long periods of time---each time the D/W is used.
Eventually the HEATING ELEMENT or HEATER RELAY fails
Nov 20, 2016 | Samsung Dishwashers
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
4 blinks / high temperature shutdown
some elemente is in short circuit. test the follow steps and fix it. God bless you
oubleshoot a thermostat:
  1. Shut off power to the heater at the electric panel and post a sign warning others not to turn it on.
  2. Unscrew and remove the electric water heater access panel.
  3. Using a small screwdriver, turn the thermostat dial counterclockwise to lower the temperature, or clockwise to raise it. If the water heater doesn't maintain the proper temperature, test the thermostat.
  4. Disconnect one wire to the upper thermostat to test it. Set a multimeter to RX1 (resistance times 1) and touch a probe to the thermostat terminals as indicated in the owner's manual. Depending on the model and the terminals tested, the tester should show infinity ( open) or about 0 ( closed).
  5. Test the lower thermostat in the same manner.
  6. If necessary, replace the thermostat. Unscrew it from its mounting and install one of the same model, size, and rating. Once you install it, adjust the thermostat following instructions in your owner's manual.
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  1. Disconnect power to the heater at the electric panel and post a sign warning others not to turn it on.
Oct 09, 2013 | Reliance Water Heaters
No hot water volume at shower until power is turned off and on to unit
follow this steps and fix it. God bless you
Oct 08, 2013 | Noritz 6.3 Gallon Residential Tankless...
Samsung washing machine error code is 6e unable to find this code
The heater isnt getting hot and the heater element is showing as faulty, hence the 6E fault code on the control panel.
There will be no short term cure for this problem either, the cabinet will need to be partially dismantled so you can gain access to the heating element and test it with a multimeter for continuity (Full electrical circuit)
You will most likely have to replace a faulty heater element in this instance. The 6E shows up for this reason. The controller has sent power to the element, but it hasnt heated at all according to the thermostat which measures the temperature (Seperate fault code for thermostat problems)
Sep 25, 2013 | Cell Phones
Fanmaster 4000 caravan heater
Yes. It seems the element is shorted/touching the tank. If you have a volt ohm meter VOM, disconnect the power to the water heater, and remove the wires from each heating element. Touch one VOM probe to one side of the element and the other to the tank. There should be no reading to the tank. The element that has a reading to the tank is the shorted element.
Oct 17, 2017 | Water Heaters
Dryer working fine, but no heat, clothes not drying
not knowing what kind of dryer hard to help you out.. if it is a standard dryer most of time back panel can be removed and access gained to heater and thermostat ... you want to gain access to the heater area and unplug unit ... taking a multi meter check the heater by removing 2 power wires and checking contuinity to heater... should read through heater and if your meter has a tone on the ohms reading should beep at you.. check the limit/thermost the same way by removing wires to it and testing.. prior to doing all this make sure the vent pipe is clear all the way through and that you actually have correct voltage to unit.. even though unit comes on it will run off 120 volts ,but the heating element requires 220-245 volts to operate... test power at the back of dryer and make sure across the power cord you actually have full power...good luck to you
Jan 27, 2011 | Dryers
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Thanks.
Jan 24, 2009 | Candy Ovens
DEF appears on freezer door and freezes up.
deF error means that you need to defrost the unit. Leave the unit unplugged overnight and defrost completely.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Estate Refridgerator
hi this component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.
Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Nov 06, 2008 | Estate TS25AFXK Side by Side Refrigerator
Miele W304 Front Load Washer Logo
32 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
