Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Kenmore side by side 59658692890
Freezer and refrigerator stopped cooling. Can hear fan, but has defrosted?
Help
  • saric283 Jun 23, 2008
    Amana side by side - 9 yrs old: lights & fan work; can feel compressor run; can't feel on/off excessive "cycling". Not cooling at all. No lint. No ice on lines. Any DIY fixes?????
    [email protected]
  • Anonymous Jul 12, 2008
    Amana side by side here: light works, can hear motor running, water dispenser works.
    Stopped cooling (both refridge and freezer), stopped making ice.
    Both refridge and freezer not cooling whatsoever
  • 61 Answers
You kenmore may be held up in defrost . you ll nead to lokate the timer and first try turnig it with a screw driver. sugjest it may be lokated in behind the covers at the rear of the food compartment .
amana is a totaly diferent unit excepy the 9 year old model . lokate you timer as well but you say the compressor runs. if the copressor runs and there is no cold then the must be eather a leak of refrigerant total loss . or inoficient compressor. eather case the fridge this problem is way to expensive to repair and out of woranty. sorry.
kenmore if the timer wasnt the problem now you look at the temp control . it is the one that actualy has an off position. you can try a hard tap with the handle of a screw driver and see if the compressor starts , if not you have to olm it out and see if it has condinuity in the on posision. hope this helps
Posted on Oct 20, 2008
SOURCE:
Freezer ok, fridge not cooling
That could be the motor up in the freezer is not working or it could be a defrost problem. If you see frost on the back side of the freezer that is most likely a failed defrost circuit. If you cannot hear the fan motor or possibly a fan switch mounted in the door jamb. Sometimes the drain can stop p and water puddles between the top and fresh food bottom. Forms a slab of ice and blocks the cold air from getting to the fresh food section.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 28, 2011 | Kenmore Top Freezer Refrigerator
My kenmore fridge model 56723 is not cooling that is the fridge side. the fan is spinning very well but the compressor is very hot. funny enough the freezer appears to be cooling okay
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 23, 2011 | Kenmore 56723 Side by Side Refrigerator
Fridge is not staying cool but freezer works and we can hear noise in the back..sound like fan is running
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator doesnt cool, but freezer works. shows 5 6 7 on freezer control settings.
werwe
wer
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
rer
Dec 31, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
Fans making noise but stop when upper doors are opened, frost built up in freezer area where fans are
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 09, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore side by side Refrigerator Model No. 253.55679403 will not freeze or cool, ice is melting and food is thawing. Light comes on and I can hear a fan or something, but I'm n ot sure. Can you help?
if you hear a fan in the freezer section when the door is open. feel the bottom of the fridge for hot air blowing. if you dont feel any hot air at the bottom, the condenser fan is the problem. if you do feel hot air then you have a defrost issue.
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Stopped cooling and freezing
check that the condenser fan is working and condenser is clean.. check that the evaporator fan is working may have to push switch in to make it run. if ice is visible behind rear freezerwall you do have a defrost problem find defrost timer and with a flat head screwdriver turn it until you hear a click and everthing shuts down. if yoou hear ice cracking you have a bad defrost timer(very common failure)you may have problem in the defrost heater but you might find that a little over your head and a repairman might be the cheapest way to go, because buying parts can be expensive and they are not returnable
Jan 19, 2009 | Kenmore 53642 / 53644 Side by Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
204 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
