Question about Toshiba Satellite Pro M15-S405 Notebook
Touchpad doesn't work on Toshiba Satellite 305 PSAGU-03601V
I disabled the touchpad with fn+F9 key and now can't change it to use it again.
  • Toshiba Master
  • 4,924 Answers
To use it again press those keys to enable..if it does not work ..just go to device manager ..and click on the pad ..and enable it (click right )
to get there click on my computer icon (right ) ..and select properties and in there select hardware and device manager ..
In the list you will find the pad under user interface devices..
If it appears in yellow and have a exclamation sign on it ..it means it has no driver installed and you need to run the driver again ..I would run the driver anyway cause this operation will also enable it ..and it may be much easier for you ..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769709&rpn=undefined&modelFilter=305CDS&selCategory=2756709&selFamily=1073768663
Posted on Dec 20, 2011
How to enable touchpad on Toshiba Satellite L850?
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Oct 27, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Toshiba laptop touchpad not working
Most likely your problem is that the touchpad was disabled. Enabling/disabling could be done in two ways:
1. press Fn and F9
2. in control panel, mouse, you will find the option regarding enabling/disabling touchpad (in some machines called internal pointing device)
Aug 07, 2011 | Toshiba Satellite L655-S5101 Laptop
The touchpad on my laptop is not working well when
Hi
You could try pressing the FN+F9 keys together and see if this helps
one of my toshiba laptops is Fn+F9 also there is a Scroll Lock and a NumLock which can be enabled/disabled while using the corresponding key with the Fn key
On some laptops there is a picture of what looks like a small hand this key is normally the touchpad key
hope this helps you
do you have your user manual it may be found in your programes or you can download one from the toshiba offical website and you will need adobe reader installed to be able to read it
www.toshiba.com
May 15, 2011 | Toshiba Satellite L655-S5096 Notebook
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Go to
Use a mouse or Tab+Aly keys
Win XP
Start > Control Panel > System
Click the "Hardware" tab
Click the "Device" manager button.
Click the cross near "Mice and other pointing devices".
Right click, "Enable"
Vista
As above but
Start > Control Panel > Device Manager
Mar 18, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
132 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
