Question about Kenmore 96563 Stainless Steel Electric Kitchen Range
How do you change the center burner of the triple burner unit on this glass top stove kenmore 790.9656
5 Suggested Answers
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
  • 2920 Answers
SOURCE: burner on glass stove top has turned black
replace the glass top with a new one
Posted on Dec 06, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore gas stove model 790, the oven will not
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
Front right burner under stove top model 62960002603 only heats to LOW heat. It has a single, dual, triple mode setting and will not heat up to highest setting. HELP.
I looked up the model number you gave. It is a Kenmore range.The part number for that element is 7406P494-60. When you say it only heats to low, do you mean that only the center portion of the element lights up? Normally, when this occurs, it is an indication that the middle element and outer elements have a break. The problem could also be a faulty infinite switch(burner control). The part for that particular control is 7450P011-60. You will need a voltage/ohm meter to troubleshoot further. This can be a very INVOLVED repair attempt. I recommend, that if you're not comfortable disassembling your unit, call for service--this can absolutely be a tricky diagnosis and much care is needed to not damage the glass cooktop when checking the element. I hope I helped you.
Aug 31, 2015 | Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Oct 16, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kenmore 96563 Stainless Steel Electric Kitchen Range Logo
55 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
