Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL40S2000 I tunred on the tv today and heard a pop. Screen is now very dim, almost black at top, and returns to normal towards the bottom. The sounds is fine. TV is less than 2 yrs old. Any assistance is greatly appreciated!
  • Anonymous May 03, 2008
    My problem is almost like yours. The top half of the screen/picture appears dim, and the picture itself seems to be flickering. My TV is nearly two years old. Help!
  • joel1 Oct 26, 2008
    turned on tv, green light went on then red light started to flash four times. no picture at all. the tv is just over two years old. any idea on what the problem is or how much the repair cost would be?
    Novelist:
  • 135 Answers
This is a backlight problem, possibly the cold flourescent lamp at the top of the LCD display panel or (less likely) a bad inverter board. To prevent further damage to the TV, I suggest you not turn it on until it's fixed. You may be able to find CCFL replacement tubes on line, but I can't say the job will be easy and you won't notice possible backlight inconsistancies. If the CCFL wires are long enough to swap, you could move them to each others connector and see if the problem moves to the bottom of the screen. If it moves the lamp is bad. If the problem stays on the top it's the most likely the inverter.
Posted on Nov 10, 2008
SOURCE:
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
215 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
