Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
ERROR CODE With our Kenmore HE3t washer, when we select the type of washing cycle, e.g. Normal, or Whitest Whites, and then press Start, the machine simply beeps. The error code is FDL. Any suggestions?
  • 370 Answers
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
SOURCE:
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
My machine keeps stopping mid cycle with an f11 error code, what does this mean?
The troubleshooting section of my manual gives a Generic fix for F codes other than F20,F21,F22 as "Select stop twice to cancel the cycle.Select DRAIN & SPIN if there is excess water in the washer. Re-select cycle and press START If problem remains, call for service."
Not much help! Try checking the inflow by removing the hose to see if there is any debris in the inlet (rust etc.) Also could be a balance issue. Rearrange load and restart the cycle.
Or it could also be a leveling issue. Use a level to see if it needs to be raised or lowered by turning one or more of the "feet" with a crescent wrench to level the unit.
Jun 27, 2014 | Kenmore HE3T Washer
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
What is kenmore he4t button sequence for
If the washer does not come equipped with a "Clean" cycle, then run the washer on it's hottest setting. "Sanitary" or "Whitest Whites" will do. Hope this helps.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
146 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
