Question about Radio Communications
Hi, i have a PRO 2025 Realistic Scanner, it is a
Hi i have a pro 2025 Realistic Scanner it is a old model that i had from tandy but i cant find the antenna i had for it. Not sure what tipe i need now these ar the freq that it operates on 68-88 135-174 406-512 Mhz (no air band) im looking for a antennt that i can fit to my car mag mount or gutter fixin. Thanks for any help you can give. Regards kev
    President:
  • 2,761 Answers
EBay has numerous antennas that will work for you, mostly in the $20 -$30 range. Here's a link to one of the listings:
http://cgi.ebay.com/NEW-MINI-MOBILE-SCANNER-ANTENNA-MAGNET-MAG-MOUNT-KIT-/220596857646?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335c98eb2e
You can also pick up a compatible antenna at any Radio Shack store.
Bill B
Posted on May 13, 2010
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Can a realistic pro 55 model 20 124 be programmed to different frequencies?
Hello, your scanner appears to be a 10 channel crystal controlled scanner. I'm estimating it to be around 30-40 years old. I think there is a couple companies still making custom crystals but you have to find the freq's #'s to give them. Here is the freq. range it will pick up. Frequency range RX 30-50 / 144-174 / 450-512 MHz I personally would take the money spent for crystals and apply it towards a newer scanner that is programmable so no crystals needed. Here's a link to some more info;
RadioShack Realistic Pro 55
Sep 07, 2015 | Radio Communications
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Realistic 2004 low audio on vhf brodcast band
Hi Did you get the answer to the low volume on wfm as i have the same problem
Jan 27, 2012 | Radio Communications
Well you will need to get it at Radio Shack,they just plug right in the back of it . nice ...hope this helps..
Mar 18, 2010 | Radio Communications
How do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Jun 03, 2009 | Radio Communications
Realistic
Hi - You can download the manual from the link underlined in blue below:
Pro-2052
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 28, 2008 | Radio Shack Pro-2052 Scanner
Owner's/Instruction Manual
Hi SDGirl - This is a slightly older model and there's not much out there. You won't find one at Tandy or Radio Shack Sites. I'll give you a link where you can find it ( sort of) in sections. I believe it will tell you everything you need to know. If I were you I'd probably copy and paste each section into Word or something so you'll have it all in one place. This is about the best out there. If this solves your problem PLEASE rate this as fixed. ( I looked alot for you). If you need more help just add a comment and I'll be happy to assist you further. If this doesn't solve your problem let me know before you rate and I'll try for something better. Thanks.
http://support.radioshack.com/support_electronics/36547.htm
Jeff
Jun 11, 2008 | Radio Shack Pro-2018 Scanner
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Realistic pro-54 scanning reciver
this unit requires crystals for each freq.
Oct 21, 2007 | Radio Communications
Radio Communications Logo
371 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
