Question about Dell Inspiron 1521 Notebook
My Dell Inspiron 1521 has had a battery problem for a couple of weeks but just taking the battery out and only using the adapter worked just fine. One night the computer shut itself down twice. The next day I started it up a blue screen showed up saying some information that I totally missed and it shut down again. It wouldn't start back up until later that afternoon but once I shut it down and tried to start it back it hasn't started since then. I have the blue light on the right hand side like it is getting power and it does make some sort of noise like it is starting up (maybe not starting up all the way though...it sounds a little quieter than normal) but the screen is black. Please help!
  • Dell Master
  • 1,183 Answers
Try running the diagnostics on the computer. You may need to repeat some of the steps that you have already done to initiate the same.
1. Remove the battery and the Ac adapter from the system
2. Press the power button for 10 seconds
3. Reinsert the battery and connect the Ac adapter
4. While holding down the FN key on the keyboard press the power button.
If the system beeps in a series on 3-3-3 or 3-3-4 the system is ok and there could be a problem with the screen.
If the system beeps in some other code . revert to the post and we would let you know where the problem is .
Thanks for using fixya
proton
Posted on May 13, 2010
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My lapto inspiron 1521 wont turn on and the hard disk LDE does not flashes.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 25, 2011 | Dell Inspiron 1521-JB Notebook
Where is the bluetooth Module/Adapter located at on a dell inspiron 1521
Turn the computer off.
Disconnect the AC power.
Flip it over.
Remove the battery.
Look at the various "covers" that are screwed shut.
Use a small screwdriver to open one of those "bays".
The BlueTooth adapter may become visible.
Or, if you open the "wrong" one, you'll see your computer's RAM memory.
May 14, 2010 | Dell Inspiron 1521 Notebook
My battery charges but the laptop wont run on the battery
If your power adapter appears to be charging your laptop battery, but the laptop will not run on the battery or only runs for a short time this usually indicates that the battery will not hold a charge and needs to be replaced. Although it should run fine with the power adapter connected.
Jan 26, 2010 | Dell Inspiron 1521 Notebook
Inspiron 1521 won't charge battery or turn on when I have the power cord plugged in. The power cord is fine and is plugged into a an outlet and not a power strip. I can start the Dell MediaDirect up using...
I see possible failure as the following:
  1. The power control strip on the Palmrest Assembly (The actual button under the hinge cover)
  2. The motherboard, even though the system partially functions under the DMD button, that is a very limited function of the system
Jan 22, 2010 | Dell Inspiron 1521 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Dell inspiron 1521 laptop won't recognize a new 90 watt power
There are different types of Dell power adapters, some of them put out different amounts of power. While it is possible that the battery is faulty, it is more likely, given your error message that the adaptor is wrong. If you got it from Dell, you can call them and they will exchange it.
Cheers
Dave
Jun 21, 2009 | Dell Inspiron 1521 Notebook
Dell Inspiron 1521 Notebook Logo
130 people viewed this question
Alun Cox
