Question about Dryers
I want to gain access to my Kenmore gas dryer model 417.93042202. Made 07/03. I need to know how to get inside the machine to replace Squeeky rollers and maybe more? There are 2 retaining clips in the back that I removed but I don't know what to do next!
    President:
  • 1,430 Answers
There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the replacement
Posted on May 13, 2010
Remove element from Kenmore Elite 110-63942101
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.
May 30, 2012 | Kenmore Dryers
My kenmore 80 series gas dryer is makinf a sqealing noise when running
May 28, 2012 | Kenmore Dryers
Must replace front drum felt seal?
The front of the dryer comes off depending on the model . I;ll list the most common ways
May 27, 2012 | Kenmore Dryers
Where is the themal fuse located on the kenmore dryer model 110.82822 102
May 26, 2012 | Kenmore Dryers
How do i check the heating element on a kenmore 400 series dryer?
May 22, 2012 | Kenmore 62602 Electric Dryer
My stacked kenmore dryer is making a banging noise when its drying it just happened out of nowhere i know nothing about dryers can anyone help me out?
Sounds like your drum roller(s) is bad. Unplug you machine and remove the panel to gain access to your drum. You will see rollers that ride on your drum. One or more of them are bad, either broken or have a flat spot worn on them.
Nov 30, 2010 | Kenmore 9387x Top Load Stacked Washer /...
Coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Dec 13, 2009 | Kenmore 72802 Gas Dryer
Kenmore gas dryer heats for several minutes ,then goes cold
I'm haveing the same problem with my frididaire gas dryer. I replaced the ignitor and cleaned the inside parts with a vacume and still having similar problems as yours. I think I will replace the temp. sensor that is attached to the flame tube inside the dryer next. To gain access to the inside parts you will need a putty knife to release the top panel. Just slide the putty knife along the top seam in front of the drryer. There are 2 clips that realease the top peice. With the top lifed up you will see 2 phillips head screws attaching the front panel to the dryer. Remove those screws and lift upwards and the front panel will lift right off the unit.carefully place the front panel to the side without damageing any wires attached. Then all your gas assembly parts will be visable in the bottom left cornner of the unit.
hope this helps,
Aug 23, 2009 | Kenmore Dryers
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
Dryers Logo
Top Dryers Experts
