Question about RCA D52W19 52" Rear Projection Television
I am looking for a capacitor for my television,
I am looking for a capacitor for my television where can I get that
  • RCA Master
  • 8,617 Answers
You can get any part for the RCA models at www.tvrepairworld.com leave them a email if youre not sure which capacitor that youre needing.
Posted on May 14, 2010
Capacitor supplier for 50 inch Insignia Plasma TV
if you are looking for a capacitor
check this site www.digikey.com
Aug 30, 2012 | Televison & Video
Turns on clicks back off
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jan 09, 2012 | Mitsubishi WT-42313 42" Rear Projection...
The tv screen shuts off every few minutes.
Good day!! That problem is usually cause of bad/faulty capacitors on the power supply board..So you have a better chances and easily locating the faulty capacitors if it is look like leak/bulged on the top.. So please try to follow this instruction on how to do that.. 1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter.. Hope it helps you..
Sep 12, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Television power light is on, but can't do anything with the television. Have tried ALL of the potential fixes listed on the web with regards to holding the power button and have also called Sharp.
Sounds like a blown capacitor on the main power board. look for the cylinder shaped capacitor on the board that the top looks bubbled up (rounded not flat). It's usually 2200uf capacitor. you will have to unsolder it and replace it or just replace the board. Capacitor $5 board moe like $200. try the cap first. they are available at radio shack. may be different in size. you will have to run extra wires to the new cap sometimes.
Mar 20, 2011 | Sharp LC37D64U 37 in. LCD HDTV
Replacing capacitors on Mitsubshi projection TV
You should start looking for any capacitor that looks like it is bulged at the top. You could also look for discoloration on the tops of them.
Make sure you use a high quality replacement and be aware that even if you find one that looks bad, you may have some that are bad but don't have any visible signs.
May 15, 2010 | Mitsubishi VS-45607 45" Rear Projection...
When turning on tv it looks wavey for a few minutes then it goes away. Also it seems like its not wanting to turn on sometimes.
could be the DM board or convergance or possibly power supply capacitor is wearing out. Further testing of capacitors will have to be done to diagnose problems. You can use a capacitor tester or voltmeter to test capacitors. Also look for burn marks or swollen capacitors.
Jul 08, 2009 | RCA D52W19 52" Rear Projection Television
No Power
Make sure that the capacitors that you replaced were the same UF as the original capacitors and that they have the same amount of tolerance. The tolerance of the capacitors is measured in percentage and should have been listed on the back of the package they were bought in. Also make sure that they were soldered into the correct position on the circuit board and you can figure that out by looking for a long black or white stripe on the capacitor and then look on the circuit board to make sure that the make matches with the side of the capacitor
Mar 20, 2009 | ViewSonic N2652w 26 in. LCD Television
Capacitor near H out
there is 3 fuses right next to your flyback FL231 they look like small square caps should read 1.6 ohm on meter, also the capacitors you are looking for are green with gold writing 2200uf 16volts
May 15, 2008 | RCA D52W19 52" Rear Projection Television
Cp150 capacitor
The "C" stands for "capacitor" and the "P" stands for power. so look on the power/deflection pcb that is on the left as you look at from the rear.
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
