Question about Furuno 1715 LCD Radar System GPS Receiver
Furuno 1622 Radar dome spins inconsistently
I was getting an inconsistent image on the monitor so I took the cover off the radar dome. The antena did not spin until I messed with it. Unfortunately, wile underway this is not a possibility. Any suggestions?
  • 398 Answers
This is a belt driven antenna. That would be the first thing to check, to be sure it’s not slipping. This should be easy to see if the motor is spinning but not the antenna that would be the problem.
I don’t recall if this model uses a “toothed belt” or not, but if it does check the entire belt for missing teeth, replace as necessary.
The next thing I would check would be the flywheel under the antenna. Check it for any signs of corrosion around the bearing. Remove the drive belt and slowly rotate the antenna see if you can detect any friction anywhere is you rotate the antenna. You could try a spray lubricant (like WD-40) but be careful of overspray, keep it off any electronics!
The next thing I would check would be corrosion on any power connections (all the way back to the main power and the fuse. Corrosion on any of the connections will lessen the current flow and make the drive motor weaker. Sometimes corrosion and salt can be cleaned off with a “contact cleaner” (or alcohol in a pinch) but if there is heavy damage you might have to replace the connectors completely. Be sure to remove all power before disconnection and connectors and be sure that they are dry before reapplying power.
Lastly (and most expensively) you might need a new motor.
If you operate in saltwater, corrosion on the connections would be my guess for the cause but I still would check these in order, from easy fix, to the expensive fix.
When you replace the dome be sure the O-ring gasket is in good condition and well lubricated with silicon grease before you close the unit. Replace the O-ring if you see (or feel) and nicks or compressions in the rubber. Take care that there are no twists in the O-ring when you reinstall it.
Posted on Mar 30, 2008
  • Ron Dufek
    Ron Dufek May 03, 2008
    I was wondering which of the problems above fixed your antenna. Either way Glad I could help and thanks for the rating. Happy boating!
    Ron
I have a apelco m88307 radar dome, can this unit be used with other type or brand screens?
do you still have this radar dome? i am looking to replace the one I just busted as I didnt have enough clearance on the barn door. my email is david.d.connell@gmail.com
Mar 10, 2010 | Furuno 1942 Mk2 Radar
I have a Furuno 1622 radar. It only shows a ring
I don't beleive this is goning to fix your problem. Open the dome and visually check that it is spinning. There is a maintenance menu though. To open the maintenance menu;
1. Turn the radar on.
2. Wait until the initial screen appears, then press and hold UP and DOWN keys together.
3. In about 10 seconds, the maintenance menu as shown below will appear.
4. Press MENU key to close the menu.
Feb 22, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Our Radar Furuno 1715-24NM On. ( Power in Oke ) but can not show drawing in monitor/lcd. thanks. regard - damanik
If you have no radar targets, go to longest range 24 miles, gain full, rain and sea minimum, do you have noise, if so, need magnetron, if not, need cable from display to dome.
Feb 07, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Hello there, I have a 4' radar antena with a
ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Oct 08, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Hi, I have a Radar Screen. Furuno 1942 MK2 . What Radar Dome can i plug this into. I have a Furuno 1720 Dome
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Sep 24, 2009 | Furuno 1942 Mk2 Radar
How can I connect a LCD monitor in furuno radar fr 2827
You need a Furuno Monitor on that unit. There are special keypad functions involved with the monitor. I have a Furuno MU201CR/DC (20 inch) that i think is compatible, if you are interested.
Sep 18, 2009 | Furuno 1623 Radar 16nm Range
Furuno radar 1621 do not show targets
You may have a faulty magnetron or one that has gotten old. They do have a life. Find out how many hours you have on the unit and give furuno a call. They will more than likely tell you what they think the problem is.
Sep 08, 2009 | Furuno 1623 Radar 16nm Range
The top half of the dome blew off while towing boat. Any way to replace the top half with a used or new piece? Don't need to replace the whole dome.
As long as no damage was done to the enclosure from the lid blowing off, there is no reason that you can't simply put a dome on it. Try contacting furuno direct to see if the part is available. Make sure you know exactly what model radar you have before you call.
Furuno Tech Support : 360 834 9300
Jul 29, 2009 | Furuno 1623 Radar 16nm Range
Connecting power inside Furuno DRS4D
polarity is maked on the shield, on a sticker #1 is positive, #2 negative BTW, this is 48V DC (not 12V) supplied from a MFD8, MFD12, or MFDBB only.
Jul 05, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1715 LCD Radar System GPS Receiver Logo
631 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
