Question about Lexmark Wheelwriter 15 Series II Typewriter
IWhen i turned it on it only types half the letters/numbers etc
One morning I cleaned the the ibm Wheelwriter Series 11 typewriter and when I turn it on to use it I only can type half the letters. I check eyerything I could think of and still not working.
  • Lexmark Master
  • 3,594 Answers
If it is only typing the top half of the letters the platen may not be fully seated in the side frames, push down firmly on both ends of the platen it should snap into place.
DickyO
Posted on May 13, 2010
2 Suggested Answers
  • 610 Answers
SOURCE: IWhen i turned it on it only types half the letters/numbers etc
It sounds like the Platen roller has popped up out of place on one side. Try pushing down on the black rubber roller (platen roller) on both ends. It is held in place by two black plastic clips that are attached to the roller ends and one of them may be broken. But usually it has just popped up on one side and pushing it down usually solves this problem.
Posted on Mar 18, 2010
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
I have an IBM Lexmark Wheelwriter 6 Series II 6784 Typewriter that is not typing the correct letter/number and at times, is not typing anything at all (no letters/numbers are appearing that I'm typing) We...
Try cleaning the sensor that lays behind the printwheel that tells the machine the wheel is in the home position, the sensor is in the print carrier. take wheel out and look down and you will see the sensor, clean it off with clean cloth. also put some white out on the top of the printwheel and see if it stops at the same place every time when you turn on and off.
Oct 05, 2017 | IBM Lexmark Wheelwriter 6 Series II 6784...
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
Mar 18, 2010 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 1500 is only printing the top half of the letters.
I have solved the problem. It turned out that the platen was not completely secured on the left end. Once I snapped it securely in place, the print was fine again. (I had to remove that platen three times to figure that out!) Sorry for the bother, but I'm glad to know where I can seek help now. Thanks.
Mar 25, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
272 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
