Question about Medical
The blue clips at the end of my electrodes were lost. Schiller at -2. How did I replace them?
    Problem Solver:
  • 10 Answers
I would call Wlech Allyn or try a 3rd party like Parts Source.
Posted on May 14, 2010
Electrode lead off light indicator
Hi I have the same problem.. of you have already solved the problem please let me know
Apr 01, 2014 | Schiller Cardiovit At 1 Ecg Machine
I have an at1 schiller it starts to print in auto mode for like 6 seconds and then stops sometime it prints the full report and sometimes it dont can u assist
hi,
You have to check two things. First you have to check the patient cable, and have to check is its electrodes are properly cleanded or not. if any one of the lead or the electrode have some problem then the machine will stop printing.
Second thing the battery inside the machine. its a 12V 2.3AH battery. If availabel try to replace the same. To replace the battery you have to oppen the machine.
ok
Jul 06, 2011 | Schiller Cardiovit At 1 Ecg Machine
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is alaronov@mac.com
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
Mar 31, 2011 | Schiller Welch Allyn Cardiovit At 2...
V4 lead not working
The Schiller AT2 is usually very reliable in terms of the pre-amplifier, which is the section of the electronics that firsts processes the incoming patient signal. Your problem most likely lies in one of three places. Most likely is your patient cable. The best way to tell honestly is substitution. Try another known good cable. The second most likely source of complaint is your Gel electrode adapters. Open each adapter and inspect the jaws, you should see only shiny metal, no gunk, paper or corrosion. You can clean minor contamination with an alcohol soaked que tip( take care not to splash alcohol into your eyes, I've done it before doing this cleaning operation. Wear safety glasses. If the corrosion cannot be removed via cleaning, then a new adapter set is called for. As your problem is specific to a certain lead, you can try swapping the adapter from V4 to a known good lead, and see if the symptom moves to the other lead, if so a new adapter set should take care of your issue, good ones run around 40-50 dollars.If neither the cable or the adapters fix your problem, I have on infrequent occasions found defective input connectors, usually the solder connections to the main PC board. If this is the case, I would recommend sending the unit to a qualified repair shop. If work is attempted on a Schiller PC board, Schiller will no longer exchange it, and you only recourse would be to replace the board, at a price in excess of 2000.00. Otherwise, it can be exchanged for far less. We repair these boards, but they are multilayer and surface mount, and this type of soldering is not for novices.
Mar 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Schiller cardiovit at-2 we can only get 3\4 of a ekg it stops
hi,
ur Schiller at 2 has problem with its battery. just replace the same. its a12v battery.
also clean the paper sensor Whit an ear bud (do not use any chemical use only ear bud). u can see the paper sensor on the side of printer head. a square black portion.
ok
Jan 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
The blue clips at the end of my electrodes were lost. Schiller AT -2. How did I replace them?
You can find these blue clips (pack of 10 pcs), called SNAP-CLIP Adapter for Resting ECG, part # 2.155031, from Schiller's web-site. You may click there.
Mar 18, 2010 | Medical
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Medical Logo
55 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
