Question about Coffee Makers & Espresso Machines
My EAM3500 doesn't froth milk; it just sort of spits it out. I have replaced the lid to no avail. Help!
I had the same problem with my machine and I have solved it following advise on http://www.wholelattelove.com/tips.cfm?ItemID=1469&tcid=6.
Good luck.
Posted on Sep 05, 2010
In my 2nd hand delonghi EAM3500 there is an extra o-ring on the coupler between black and red o-rings. Is it a wrong part installed or just an old model. Milk frothing is also not working properly.
check for a hole between the green and black rings
if there is one it is used to separate materials like coffee, milk or hot water for the machine to operate properly
Jul 08, 2016 | DeLonghi Coffee Makers & Espresso Machines
ESAM6600 will not froth milk
Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath
I had frothing problem as mentioned above and noticed this tube was blocked, its 4 years I have had the Gran Dama 6600.
Cleaned as mentioned and did some purge as I went along, now it works as new. Its a maintenance that should be done once a year. You learn as things happen. LOL
Mar 17, 2012 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi EAM3500 ..milk wont come properley
We had a similar problem and it required a replacement coupling block. Part No-111 on the Delonghi part breakdown pdf
Jun 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Milk frothing problem on a Magnifica 3500
Had the same prolem replaced the coupling where the jug clips in. Item 111 - part number 5532123200 coupling. If your not technically experienced then you may need to take it to a service agent. Had to fairly well dismantle machine to complete repair.
Apr 07, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
I have a Delonghi EAM 4500 and it does not froth/Foam the mil, I have replaced the milk cover lid 3 times, still it works for a short time then stops.
remove the o rings where the milk frother connects to, there is a green, red and black rubber O ring. Remove them and get a toothpick and clean around where they sit. You will notice a hard milk build up like when you get on your teeth. This is what
tbirdfan1 says:
may be causing your problem the o-rings are not setting their properly
tbirdfan1 says:
here is some more information
tbirdfan1 says:
It turns out the electrical connection for the solenoid valve that feeds the hot water out into the milk jug/hot water tap had come loose. They are clipped on rather than being soldered into place. Trace the wires back to the main board from the sole
tbirdfan1 says:
from the solenoid (brass bit with grommets) and check that the clips are in place.
Nov 10, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino Overflows
As a Nespresso demonstrator I've had this question many times- use the black plastic wand for light foam- can use to max line. Using the wire whisk wand for heavy, cappacino foam and fill only to bottom line. This wand uses more aeration to achieve foam density- causing more pressure and your leaks. The wand stored inside the lid doesn't have anything to do with function of the aerrocino.
Jul 06, 2009 | Nespresso Aeroccino Automatic Milk Frother
Milk not frothing
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Jun 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
