Question about Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier
Plug In the back of my radio I can not find a plug that will fit. any suggestions on where I might find this item?
  • 88 Answers
Hi, if you don't have any RCA plug on the back of your radio you can't plug your amplifier :(
Posted on Mar 31, 2008
Clarion cd changer manual
My suggestion would be to check out your local ICE specialist or find the local Saturday night car gathering and see who they recommend.
Sep 05, 2014 | Clarion Infiniti I35 Nissan Maxima Cv737...
In my apartment all radios have to much buzzin on most stations somtimes
likely causes ------- plasma or large screen tvs, central heating pumps fridge or washhing machine motors,cheap chargers for mobiles or computers especially chinese ones, wifi modems, some cordless phones, florecent lights, a faulty low energy bulb, fish tank equipment,.......best thing to do if possible is turn everything off in your apartment and see if its still there, if it is then its coming from someone elses apartment so youl need to fit an external arial..if turning absolutly everthing off stops it then go round turning each item back on individualy checking the radio after each item and hopefully that will expose the offending item. good luck!
May 20, 2014 | Audio Players & Recorders
My radio will not turn on i dont know where the fuses are so i havnt checked them
Most portable devices have a thermal fuse built into the transformer instead of using traditional fuses. I suggest installing batteries to check if the radio will come on, if yes! the plug in ac power is the problem, if no! the main processor in the item is the likely cause and the radio should be replaced. If you unscrew the back and remove it, follow the plug in to the circuit board where the fuse should be located if there is none, the power transformer is fused on the inside, only option is to replace transformer, but not cost effective.
Feb 27, 2012 | Dewalt DC011 AM/FM Radio
Just fitted a cd/radio to to my 03 fiat punto. the cd player works great but the radio is rubbish,terrible reception no matter what i do. the correct connection is in the back of it. i love the radio. help...
This may not be very easy. Presuming that the aerial cable was already there and there was a standard plug on the cable that fitted into your standard socket on the radio, and presuming that you are confident that it all fitted OK, then the problem is with a faulty cable or aerial.
Just before you start, can I suggest that you DO test the radio and check that there is no fault in it. Particularly if you have removed an old radio with perfectly good reception. You might want to take it back to the shop and ask them to hook it up and test it for you. If the radio is clearly good, then my thoughts are as follows:
Typically the fault will eventially trace down to a portion of the outer copper brading in the cable being in contact with the inner core that carries the radio signal. This is usually right at the end in the plug and it's worth cutting off the plug and refitting a new one as a first step (You might even be able to carefully bare the inner core of the cable and push it into the cernre hole in the socket of the radio and test it before the new plug is fitted).
The second area of failure is typically the point at which the cable reaches the car aerial. It's not uncommon for water to get into a seal wher it is attached to the body and affect the performance of the aerial. Once again, you MAY be able to snip the cable at this end and re-make a nice clean dro connection. I have to be honest and say I don't know how the fitting go in this vehicle, so I'm shooting in the dark a little here. Obviously, if the vehicle has a built in aerial in the windscreen or back window somewhere, then my last suggestion is pretty redundant.
Finally, having tried to re-make connections at both ends of the cable, it's potentially time to buy a new aerial and cable and re-fit the whole thing from end to end. This is not a very fun job!
Jul 28, 2011 | Fiat 124 Cars & Trucks
Our company bought many Uniden GMR1235-2 radios, but the belt clips keep breaking and I can't find replacement belt clips. Can you help?
The link shows a belt clip available from Uniden for 30 cents. Before you order though, I suggest that you contact Uniden (Click CONTACT at the top of page on the link) to verify that this part will indeed fit your radios.
http://www.unidendirect.com/itemdetail.cfm?item=GMR1235-2Q&tabid=2
Mar 16, 2011 | Uniden GMR1235 Two Way Radio
Desperately looking for wiring colour codes for Audi A4 1998 'concert' stereo radio - in order to fit a replacement stereo.
I suggest you contact Crutchfield Radio and buy adapters from them; they can help you for free when you buy items from them. Go to Crutchfield.com okay?
Aug 20, 2009 | Car Audio & Video
Hooking up audio
Unfortunately, even if you get the wiring sorted out, the Ford radio chassis does not fit in a GM - the mounting is entirely different. The wiring harnesses and colors are also entirely different. Maybe best to find a GM radio - most of the GM radios should fit and plug right in.
Apr 18, 2009 | Car Audio & Video
Multi media car stereo
If you have a vehicle that can fit a 'double-din' sized radio, I would suggest the Pioneer AVH-P4000...$500 without the extras. Easy to add an i-pod cable, has back-up video hookup. Also bluetooth ready as has capability for satellite, hd radio, and tv tuner if you ever wanted to add them.
May 11, 2008 | Car Audio & Video
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Jensen 100W x 4 Amplifier KA5 Car Audio Amplifier Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
