Question about Sony Handycam DCR-DVD108 DVD Camcorder
Recover footage after formatting
I removed my disc before finalizing, put it back in and then it asked me to format. Not knowing that format would wipe the dic clean, I pressed ok. Is there any way to recover the footage? Please help.
My son accidently formatted the disc in the handycam is there anyway of getting the recorded video back please thanks
Posted on Nov 24, 2008
Lost footage trying to get it back
You can try to recover your recoding with the help of data recovery application. Download one such application from http://www.fileundelete.org/ and recover all your deleted or lost data.
Mar 12, 2013 | Sony Handycam Video Cameras
Hi..I have a Panasonic VDR-D160GN video camera. I only know the basics of its use. eg, I know i have to format/initialize a new disc and have to finalize it before playing it somewhere else other than in...
When i have had that happen to a customer i have had to replace the dvd drive assy to take of the problem. Your videos on your disc should still be retieveable once the drive has been replaced, also ask for any firmware updates for your drive assy. I hope this helps
Sep 04, 2010 | Panasonic VDR-D100 DVD Camcorder
Hi I formatted a disc I had finished recording on for use in dvd players but have now lost all of my footage is there any way to restore this?
You may be able to get some freeware software that can recover data from the disc you have formatted but i would not be too confident about getting any files back.
most normal formats tend to remove just the table of contents from the device so it "forgets" about the data on it, but i belive the format you may have done would have cleaned out the entire disc read for use in DVD players.
its worth having ago with the data recovery software first it might work.
Dec 30, 2009 | Sony DCR-DVD708E DVD Camcorder
Asking to format full disc
The simple trick is to put a disc into desktop DVD recorder. If Your DVD will be recognized, then copy all content to another DVD or camera. I've seen it before. Must work. Sincerely.
Sep 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I have attempted to finalize a DVD after viewing the footage.
try to use sony discs they are already formatted for sony video cams. less likely to getting errors. try putting it in a cpu and finallize from its burner drive. if not basically you have lost all the footage.
Jun 01, 2009 | Sony Handycam CCD-TRV37 Camcorder
Camcorder disc footage not viewable
try to put it on your dvd rom of computer and see if its working. if you can see the files on your computer, then burn it in nero sofware. so that i will watchable by your dvd player. hope that helps!
CHARCOIS
Oct 02, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Once finalising is complete, put the disk into the PC.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Disc will not play... camcorder wants to format the disc and says it is empty.
There is a software program that always saves me when I get careless and fill the disk to full. It''s called CD Roller. It''s called CD Roller.
Jan 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
414 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
