Question about Panasonic PT-47WX42 47" Rear Projection Television
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
My problem is curving blue and green colors @ the top and bottom of screen going from side to side of screen. Its like a wave bending blue and green (blue on top of green) colors, 1 wave of colors on the top and 1 wave of colors on the bottom of screen. The degree of intensity is depending on the picture.
I went thru the convergence as follows:
Convergence #1:
1) OK, green scope sights lined up with marks on cabinet.
2) OK red centered fine
3) OK blue centered fine
Convergence #2
1) OK, red all centered fine
2) a. BAD, blue is high on the outer upper top marks (top center is just okay).
b. Center screen marks are okay.
c. Bottom marks-blue is high on the bottom left and center marks. Right bottom was just okay.
I turned this problem in once before, paid the $10 and forgot to write down the password and user:) Its okay. I just would be happy if someone could tell me if the TV is not worth fixing or does it have a chance. Thank you
  • Panasonic Master
  • 13,433 Answers
So what bestdarngood was saying, yes it can be repaired, but if you arent trained or knowledgeable in the internal workings of electronics / tvs Id take it a professional, since the tv uses high voltage it can be dangerious.
Posted on Mar 29, 2008
  • 3,037 Answers
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
SOURCE:
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Rca projection tv
this is a indication of convergence problem. the curved picture indicates total or a complete loss of convergence power. I first recomend you read the artilce in tips in tricks section. the fl231 problem it might be this if you do not have the convergence options in setup of customer menu. if not it might be a convergence power board issue
Oct 12, 2008 | RCA HD52W59 HDTV Projection Television
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Panasonic PT-47WX42 47" Rear Projection Television Logo
295 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
