Question about Canon MultiPASS F50 All-In-One InkJet Printer
How do u unblock a printer head - Canon MultiPASS F50 All-In-One InkJet Printer
  • Canon Master
  • 19,396 Answers
Remove cartridges first.
Buy an head cleaning kit, or a head cleaning solution.
Squirt a little solution onto the ink pads where the ink cartridge sit and wait for the solution to get absorbed.
After doing this try gently to move the head.
It may not work at first chance do the cleaning a couple of times
If this still does not work, there should be a grey locking lever in the front of the carriage for the print head. You should be able to pull up gently on the left side tab and release the top of the carriage and pull out the head completely. If it does not come you will need to use more cleaning solution.
Once you pulled head out put beck the head in place and ensure it moves smoothly. If it does not, you may need to change the printer head.
Regards
Posted on Mar 29, 2008
When printing its very light and it skips a line epson RX595
I take out the cartridges to reveal the print heads within the carriage.
Then connect a syringe with a pipe on it filled with cleaning fluid and force the fluid through each print heads. Please follow link.
http://www.specialistinks.com/unblock-printer-heads.php#
Dec 09, 2013 | Epson Office Equipment & Supplies
Tip
How Can I Make My Old Printer Cartridges Work .
Step 1: Remove the cartridge from the computer
Step 2: Soak the tip of the catridge in a luke warm water / If some ink runs in the water, it means that the holes have been unblocked.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Step 3: Or with the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
Step 4: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
on Feb 02, 2010 | Office Equipment & Supplies
My printer was sent in for repairs, the person checking it said that the printerhead was blocked and that it is uneconomical te repair. Is there anyway that this can be fixed as I like my printer. How do I...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 29, 2011 | Canon Pixma MP500 All-In-One InkJet...
Nozzle head blocked been through all the procedures to try and unblock
The nozzles are block, this is cause be periods on non use. The print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 18, 2011 | Canon PIXMA MP960 All-In-One InkJet...
Wont print. sounds like it is printing, everything moving and looks like it is working, still nothing, tried replacing ink. still nothing ?
Have you performed a head clean? If your printer has not been used for a while it may take several head cleans to unblock the inkjets.
Jan 14, 2011 | Epson Stylus CX4800 All-In-One InkJet...
La impresora aunque me indica que los cartrige estan bien no imprime,trato de hacer una imprecion de prueba y tampoco funciona.
Hello.
Inkjet printers have the major disadvantage of having often having clogged print head cartridges that can be very annoying in the long run. Though advanced inkjets might possess their automatic print head cleaning process, this might not work every time. The problem might be because a layer of
Using a syringe and some alcohol to unblock the holes can be very effective.
Step 1: Remove the cartridge from the printer
Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
Step 5: Run some test prints before using the printer normally.
Hope this resolves your problem.
Nov 27, 2010 | Lexmark Z845 InkJet Printer
Dirty print heads that wont clean themselves
That is correct, they won't clean them selves when they get too dirty, trying to clean them from the maintenance in those cases will make the problem worse.
You should get some Magic Bullet solution for your printer.
http://www.specialistinks.com/cleaning-heads.php
make sure you watch the "Watch a video on using Magic Bullet to unblock printer heads, see how easy it is to remove even the most stubbon blockage."
Dec 15, 2009 | Canon I960 InkJet Photo Printer
My 656c printer, takes the paper, but do not print. plz help me.
The printer head most likely has some dried up ink that is blocking the actual ink getting to the paper. The printer head would need to be replaced or the printer head would need to be cleaned.
here is a solution to getting the printer head unblocked. Its called magic bullet, do watch the video they have on the page for a demonstration.
Nov 15, 2009 | HP DeskJet 656c InkJet Printer
Blocked print heads
sounds like ink has dried up in the ink ducts in the printer head (due to lack of use)
you can try performing a head cleaning (which should be accessible via the maintainance menus)
if this fails you can try (gently) wiping the print head with a damp tissue to try moisten the dried ink, then try head cleaning again
Apr 28, 2009 | Brother Multi-Function Center MFC-240C...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
