Question about Bulova Watch
Need instructions on setting Hype water resist 330 ft
How to change date on shhors digital watch
Use the S button on the lower right to cycle through the minute, hour, date, month, and day of the week, and use the D button on the upper right to change those things. Push the M button one more time to get back to normal operation. To set the alarm: Setting the alarm is the same as setting the watch.
Amazon.com: Customer Reviews: SHHORS Sports Water Resistant ...
https://www.amazon.com/SHHORS-Sports-Water-Resistant.../B00WDPZWYY
shhors digital watch instructions - Google Search
Apr 08, 2017 | Watches
How o set my watch to the correct time date and day please my watch is a citizen eco drive wr 10 bar
Setting Instructions - Citizen Watch - English (CA)
www.citizenwatch.com/en-ca/support/setting-instructions/
  1. Cached
  2. Similar
Need additional assistance? Our support team may be reached at: 1-800-461-4189 8:30AM - 5:00PM EST, Monday - Friday customerservice_ca@citizenwatch.
[PDF]instruction manual - CITIZEN WATCH Global Network
www.citizenwatch-global.com/support/pdf/8720/e.pdf
  1. Similar
Visit the Citizen web site (http://www.citizenwatch-global.com/) to view visual guides for ..... Eco-Drive watch handling precautions ... Water resistant to 10 or 20. citizen eco drive wr 10 manual - Google Search
Apr 06, 2017 | Citizen Watches
At size is the battery in a mens fossil blue watch
take to Walmart and have them put in a new one .
Feb 15, 2015 | Fossil Watch
Chronograph, sport watch, water resistant 165 ft. the alarm goes off in the middle of the night and I don't know how to set the alarm. All the web sites refer to A, B, C. Well I have reset, mode...
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
This site gives an illustration showing the button labels, so it should solve your problem.
Jun 03, 2011 | Armitron Watches
My husbands new watch Armitron water resistant Quartz alarm chronograph, two tone blue face 20/1441 T205 ( water resistant 165 ft ) it came with no instruction manual,the alarm beeps every hour , anyway...
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Feb 23, 2010 | Watches
Water under crystal
Obviously you have moisture inside the watch. If the crystal is not cracked then moisture can get in around the stem if the seal is no longer good. Although also possible is from a bad seal on the case back. These seals need to be replace every 3 to 4 years and then properly lubricated with a special silicon grease. With time, the seals will tend to flatten out and the grease will dry out. So get it serviced before the moisture will permanently damage it. Also. 330 ft is if you decend slowly. If you jump in a pool or subject it to a heavy spray, like in a shower, that is another story and they don't always keep the water out then.
Dec 12, 2009 | Watches
Watch Instructions for AW60526W
Steve,
I have the same watch and the same issue. I believe it is a casio and I have after several months figured out how to set it.
press the bottom right button (laps button) and hold you will see after a second the word set and then the seconds will be flashing use upper right to change #'s , bottom left to switch what you want to change
msrhondabaker@yahoo.com
Apr 11, 2009 | Watches
INSTRUCTIONS FOR SETTING UP A POD 510 WATER RESISTANT MENS TIME WATCH
my pod watch will not restart,it's frozen,also can't find instructions so I can set correct time.
Aug 26, 2008 | Watches
Bulova Watch Logo
53 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
