Question about Boating
I want to install a 12 volt power point like the car lighter plug in my boat. Can it be done and how?
  • 2,926 Answers
You can purchase this socket/connector at any marine store. You'll have to drill a hole large enough to slip the connector thru, but small enough so that it does not fall thru. Their should be hole dimensions listed on the pkg. Then, all you will have to do is run a positive wire to the postive battery or existing battery hot lead, and run a ground to the battery or exisiting ground lead. Also add a fuseable link to protect the circuit.
Posted on May 14, 2010
How can i power my cpap sleep machine while camping
I bought a 12 volt DC power supply mechanism from cpap.com that can plug into the cigarette lighter of a car or truck, or be connected to an external 12 volt battery. Car batteries can only be drained and re-charged a few times, without damaging the battery. But marine batteries are available, used by fishermen to run electric trolling motors on their boats, that can be recharged indefinitely. They are heavy.
Apr 19, 2013 | Office Equipment & Supplies
Wiring diagram for installing a tv on a boat
Depends on whether this is a 12 Volt TV or a 120Volt. If a 12 volt, then fused and direct to battery. This is done this way as you do not want any other circuit to feed through it. You may want to add a diode to insure that if this is a unit with its own batteries, there is no reverse draw.
If a 120Volt, you need a power inverter which is also isolated from other systems. For shore power 120Volt, there should be a circuit panel and it may have open taps.
Jan 24, 2012 | Boating
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
I unplug my battery , and when I plug again my radio doesnt work , the radio ask me for a code what I do?
Each time you disconnect the battery, the computer loses all codes for security system, radio, etc. If you know the code for radio, enter it into radio using the number buttons. To prevent this again in the future, you should purchase a power cord for the computer. It has the lighter plug on one end and a plug you connect to the car's computer. Plug the lighter plug into any 12 volt plug (not the lighter socket in your car)...you can purchase a portable jump starter with the 12 volt socket. The purpose of this is to keep the car's computer "powered" while you disconnect the battery.
Nov 13, 2010 | 1999 Honda Accord
Yes. You can do it several ways. If you have a metal boat use 2 wires pos/neg with a fuse if you want fulltime power. Or in a Fiberglass or wood boat, 1 wire from POS and fused and have the GRD wire to catch a grounded wire closer to the appliance.
If you have a fuse panel, you can use the panel for power. But if you want fulltime power you will need a fuse that does not shut off with the ignition. Or you may want it to only work when the ACC side of the switch is on.
You can also add a panel switch if you want to control it that way instead. You just need to watch that you are not energizing the whole fuse panel from the 1 hot terminal you are using. Stray voltage can cook parts that are suppose to be off and also cause Electrolysis.
Mar 18, 2010 | Boating
Where can I find a wiring diagram to install a generator into a boat? I know how to wite the 110 volt side but where do I connect the 12 volt power from the generator into the 12 volt distribution panel?
Installing a generator into a boat is critical to be done correctly. You need to contact the manufacturer of your generator for approval, and wiring diagrams. If done incorrectly (which if you are connecting 12v from gen), you may create eddy fields that can cause galvanic corrosion, not to mention electrical shock hazards.
If your generator isn't marine rated, then don't install it into a boat.
Portable generators can be used, but don't hardwire those into a boat. Just use extension cords to the appliances you want to power.
Nov 22, 2009 | Northern Tool Electrical Supplies
Garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Apr 20, 2009 | Garmin GPS 12XL GPS Receiver
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Battery dead; cannot open hood
If the cigarette lighter is an unswitched power point you could use it as a location to put a very small charge, just enough to get the hood release solenoid to activate. Years ago there was a device that was a male cigarette lighter power point at both ends and enough cable to go from car to car. DO NOT ATTEMPT TO DO ANYTHING ELSE EXCEPT OPEN HOOD, DO NOT TURN KEY TO RUN OR ATTEMPT TO START. ANYTHING COULD RESULT. MINOR OR MAJOR. THERE IS A COMPUTER MEMORY SAVER THAT MATES A 9 VOLT TO A MALE CIGARETTE LIGHTER PLUG THIS MAY NOT BE ENOUGH TO RELEASE HOOD BUT MAYBE WITH A 12 VOLT FLASHLIGHT BATTERY (2 6 VOLT BATTERIES) WOULD WORK TO OPEN THE HOOD. (TURN EVERYTHING OFF EVEN DOME LIGHT.)
Aug 23, 2008 | 1999 Porsche Boxster
Installing tv in boat
You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
Sep 15, 2006 | Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready...
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
