Am trying to mount a seagate expansion on my mac but when I go into disc utility to erase the file formatting and replace it with mac Compatilibity I get an error message. Can anybody offer advice as to how to solve this problem. After one go at re-formatting it the hard drive no longer even registers on my computer. Am using a new Mac Powerbook with Mac os X. Any help much appreciated.
  • 721 Answers
The jumper on the back of the drive is probably in the wrong spot. Look at where the jumper is on your current drive. I ran into this working the other way, taking a mac drive & formatting for windows. Had to remove the jumper completely & then it was seen as a normal drive. Mac setup is alot different then just tossing a drive in. For personal assistance I reccomend you to my Mac guy,Kevin. Email; him at shox88@hotmail.com , I'm positive he can get you straight quick. Just tell him Pete sent ya.
Posted on May 15, 2010
How do I format for a Mac?
1. Open Disk Utility
Applications > Utilities > Disk Utilities
2. Select the Se agate drive on the left.
3. Select Erase which opens the following window.
4. Rename the drive
5. Select OS X Extended (Journaled) for Format
6. Select GUID Partition Map for Scheme
Warning: Formatting the drive will erase all data on the drive, so you should copy any data you want off the drive prior to formatting.
7. Select Erase again.
8. Disk Utility will start formatting the drive.
9. Once complete, click done.
Dec 12, 2015 | Seagate Expansion 1 TB USB 2.0 Portable...
How to write to a seagate hard drive from a mac
you will need to reformat the seagate drive if it has not been formatted for mac.to do this.
connect your seagate drive to the mac.go to spotlight the magify glass at the top right corner and type in disk utility and select disk utility
in disk utility make sure you select the seagate hard drive and choose erase. at the middle of the screen look for format and choose mac os extended. click erase.
you should now be able to write files to your seagate drive.
also if you would like be able to transfer files to and from a mac or PC then you will need to format the drive as FAT.
Feb 15, 2012 | Seagate 1TB FreeAgent USB 2.0 External...
HOW DO I ERASE A DISC.? DO I NEED A SPECIAL PROGRAM TO ERASE A DISC? PLEASE ADVISE..... THANKS
Open "Disk Utility". This comes with the computer and can be found in your Applications -> Utilities folder.
Sep 26, 2011 | Apple Mac OS X 10.5.4 Leopard for Mac
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My new seagate go flex hard drive is being read by mac but I cannot do any modification, which includes data transfer!!
Most likely the hard drive is formated as NTFS and you will need to download a 3rd party app in order to write to an NTFS file system in Mac OS X, such as Tuxera NTFS or NTFS For Mac OS X
NTFS For Mac OS X http://www.macupdate.com/app/mac/26288/ntfs-for-mac-os-x
Tuxera NTFS For Mac OS X http://www.tuxera.com/products/tuxera-ntfs-for-mac/
Apr 05, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I have a powerbook G4 and just purchased a Seagate 500 GB external hard drive and i can not drag and drop do i need to format something or what ?
Yes.
You should use the Disc Utility in Macintosh >Hard Drive> Applications>Utilities>Disc Utility to format the new externql to Mac OS Extended Journalrd or non-Journaled is fine.
For video applications I prefer non-Journaled.
Select the drive on the left side of the window to highlight it.
Select the Erase tab. (Top of window)
Select VolumeFormat: and Name:
In Secutity options select Zero Out Data, hit Erase (middle of window) and wait for formatting to complete.
Could be an hour or two depending on disc size.
Apr 03, 2011 | Apple PowerBook G4 Mac Notebook
My mac OS X 10.4.11 won't let me drag and drop into Seagate Expansion 500GB - says it can't be modified!!! Help please.
If the drive is formatted with NTFS (the format used by recent Windows operating systems), then you won't be able to write to that file system.
What you will need to do is reformat the drive to HFS or FAT32.
If you will be moving the drive between a Windows and a Mac, then you'll have to format with FAT32. If you will only be using the drive on your Mac or other Macs, then format the drive with HFS.
NOTE: unless you copy the existing files off of the drive first, you will lose all data on the drive.
To do this, do the following:
  • Copy all existing data off of the Seagate drive to a safe location
  • Unmount the Seagate hard drive
  • go to your Machintosh HD / Applications / Utilities folder and start "Disk Utilities"
  • Select the Seagate drive from the list
  • click on the Erase tab
  • Select the Format. For HFS choose "Mac OS Extended (journaled)" for FAT32 choose "MS-DOS FAT"
  • Type a name for your volume in the Name: field
  • Click the "Erase..." button and allow the Disk Utilities program to format the drive
  • Once the drive is formatted, you will be able to save files to the disk.
Thanks for using FixYa and have a great day
Jan 15, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Seagate for Mac
yes you have to mac format it, this deletes all your files. use the disk utility in the utility folder an erase with mac extended
Mar 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
David Payne
David Payne
