Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell ClearView powersteamer carpet cleaner does not seem to be dispensing water in the pre-treat mode
    President:
  • 1,673 Answers
Pretreating (optional)
Note: Pretreating is recommended to improve
cleaning effectiveness for heavily soiled carpet in
high traffic areas such as entryways and hallways.
A.
Spray the BISSELL Tough Stain Pre-treat formula
onto heavy traffic areas, soiled areas, or stains.
B. Allow to penetrate for at least 3 minutes.
Maybe isn't su[pposed to dispense water, just the Pre-Treat solution. Then after a few minutes, shampoo normally.
Posted on Mar 30, 2008
6ya staff
SOURCE:
Bissell powersteamer won't dispense soap
Check to make sure the tank is installed completely. Turn off unit and unplug it. Then reinstall the tank, plug in the unit, wait one minute and turn it one. Check by using the sprayer. If that didn't work call the Consumer Care at 1-800-237-7691
Sep 24, 2014 | Bissell Powerclean Powerbrush Pet Carpet...
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Powersteamer problems
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Feb 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Can't reassemble top of carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
423 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Marvin
Marvin
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
