Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 code keeps showing up whats going out on my machine
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^@#
Posted on Sep 20, 2010
On my kemore dryer I keep getting a F1 that keeps coming on what does that mean
go to google and input the make,model, and error code to get the code meaning
Mar 08, 2015 | Kenmore Dryers
The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer keeps shutting off and F1 shows up on the display.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
Whirlpool Cabrio is showing a error code of F1 what does that mean?
Typically, we're going to be looking at a pressure sensor failure here, although there are a few possible culprits. There's some pretty detailed troubleshooting here:
http://www.managemylife.com/mmh/questions/195601-why-does-my-whirlpool-washer-model-wtw6500sw1-display-the-fault-code-f1
Jul 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
My washer keep showing F1 error and then stop, I clear the code, start againg and in a few minust will show back F1 code and stop
Remove the three screws in the back of the control panel and lift the control panel up. You should see a clear plastic tube to the far right going into a gray plastic box.
There is either a kink or break in this hose or the controller board (the grey box) is bad.
Try removing the hose and blowing in it to check for any resistance (clog).
I just bought a controller and they run about $200
Jan 10, 2010 | Maytag Bravos MTW6600T Top Load Washer
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
