Question about Microwave Ovens
Sharp R3A52 worked OK until low voltage yesterday. Now, cannot get settings to work. Reprogrammable? If so, how to do it? Thank you.
    Guru:
  • 1,894 Answers
The power problem caused by the cook cycle starting is resulting in changes to the settings or else the microcontroller is not interpreting them properly. This may be due to a faulty part of bad connections in the controller or elsewhere. As with intermittent problems, a thorough search for loose ground and other connections and bad solder joints may locate the source of the difficulty.
Posted on Mar 29, 2008
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
My GE SCB1001KSS Convection Microwave does not work.
If it has a turntable does that work or not?
Oct 15, 2012 | GE Microwave Ovens
I have a Sharp Model 1460A Microwave. It quit working while warming something up yesterday. Outlet is good. No power to unit at all. No light working, etc. Is there a fuse that I can check to see if it...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 07, 2011 | Sharp R-1460 Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
Sharp 953 as if not plugged in. checked fuses internally and external all ok. Power goes to control panel although tested with volt tester pen.
The control panel circuit board may need repair, and it's possible the low voltage transformer has failed.
Some do it yourself tips here.
Info on ordering Sharp UK parts / spares is here.
For local servicers, see this page.
Aug 18, 2008 | Sharp Microwave Ovens
Wattage
Look on the back for the power requirements, them muliply the number of amps drawn times 100 . example 10 amps times 100 = approx 1000 watts, that will give you an approx. wattage. hope this helps
budman630
May 12, 2008 | Microwave Ovens
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
