Question about Watches
How do I remove the stem and crown from a Skagen watch? There seems to be no set screw at the base of the stem.
    Scholar:
  • 93 Answers
First, this isn't something you should do if you are not a trained watchmaker. Many people cause more damage by trying to repair their own watch just to save a couple dollars. But the movement (insides) of a watch are very fragile and some parts can be damaged by touching them with too much force.
If you are a watchmaker you need to remember to look for the detent. That is what you need to remove the stem.
Ken
www.yellowstonewatch.com
Posted on May 13, 2010
Skagen solar watch
try pushing then screwing it in
Apr 08, 2013 | Skagen 233LSS Wrist Watch
The crown unscrews and comes of is this normal Is there a spring inside?.
The crown is attached to the "stem" by screwing them together. The procedure, and this is not a good do it yourself project in most cases, is to remove the crown and the stem. Hold the stem in a "pin vise" and apply a threadlock to the threads and attach the crown. Install the crown and stem in the watch and check to see if everything still works(setting, time adjustment, etc.) Might pay to have a watchmaker do this, this is more technical than it seems.
May 24, 2011 | Watches
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
The crown seems to be stuck out in the set position. It looks like something is behind it stopping it from going in.
mcdevito75 Here, That muct be part of the Mechanism itself behind the crown, Best Bet, look for a small watch repair shop in your area to fix the watch, as the watch could be ruined by trying to get a stuck crown and stem back in. Or you can visit the repair service directory here at fixya, bottom of the page click on repair serice directory then watches.
Jul 01, 2010 | Skagen 590SGS Wrist Watch
My watch is not working and it is brand new. do
Look very carefully just under the crown (winder knob) for a piece of plastic used to keep the stem from being all the way down to start the watch. Remove that small piece of plastic, press down the crown and the watch should start. mcdevito75
May 28, 2010 | Skagen Alarm Function Leather 519XLSL1...
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
599 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
