Question about RCA P52937 52" Rear Projection Television
No sound no picture
Chirping noise
Just had problem simialar try the transformer.ran me three hundred at tv clinic with labor
Posted on Apr 13, 2008
  • RCA Master
  • 8,617 Answers
That is usually caused by the horizontal output cisrcuit or the flyback. Can you post the chassis number as RCA has to be diagnosed by chassis number.
Posted on Mar 29, 2008
SOURCE:
No picture/ chirping noise
Common problem with this model. Goto www.TvRepairKits.com for a kit with instuctions.
Jan 30, 2009 | Philips 60PP9401 60" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
No Sound or Picture, Chirping Noise coming from back
There are many other fuses on this board you need to check them all. May need a schematic.
Dec 03, 2007 | Philips 51PW9363 51" Rear Projection...
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
