Whirlpool washer LSQ9659pw4, very excessive vibration and walking
Whirlpool lsq9659pw4
hello, we have the above noted unit and ever since delivery this thing shakes and walks excessively. Here are the details, we have checked for left over shipping materials as per manual (none exist), have had the whirlpool tech here, stripped the casing and said nothing was wrong with the unit. Since rebalanced a total of 9 x and had our home builder in to rip out the floor in the second floor laundry room and reinforce (which they did excessively so the floor is very sturdy).
But, the unit just keeps getting worse and drives us insane, even redistributing loads does not help. Any of you experts have any ideas. The unit is only 1 1/2 years old and problem since day one. Sitting in a second floor laundry closet in a galvanized lined area with a drain in the center. Thanks in advance for any ideas
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
There's a very good chance that you have a bad ballast ring. it is a balancing device that is located at the top of the spin basket. part # on your washer is 8519788.
Posted on Jan 18, 2010
    President:
  • 1,314 Answers
Hello im proably the only one that will jump on this how old is this unit
Posted on Mar 29, 2008
  • robert samples Mar 29, 2008
    ok i see the age sorry good reporting by the way .why didnt you just return it it at the first do you know how to remove the case
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
I have an older whirlpool washing machine model # LSQ9659PW4. The damn thing fills up with water to start and then stops working after that. I think it could be the lid switch but I am having a hard time...
yes this sounds like the lid switch if needed you can take a jumper wire and stick one end into position 1 and the other in postion 3 on the connector which would cause you to jump past the lid switch this is a temporary repair if your looking for the switch itself goto www.marcone.com under contact us there is a 1800 number if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Apr 02, 2011 | Whirlpool Washing Machines
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
Kenmore 70 Series Washing Machine, Vibrating problem
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the
washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the
same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
Mar 01, 2010 | Kenmore Washing Machines
Maytag Model #LSQ9659PW4, where is the lid switch located?
Its located at the rear left hand side under the control panel & is held in with 1 screw.This link should help..........
http:/ww/w.partselect.com/ModelFrames.aspx?ModelID=702773&ModelNum=LSQ9659PW4&mfgModelNum=&ManufactureID=3&Selected=GR7FRVVY&Position=6&mfg=Whirlpool&Type=&Mark=6
Jan 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Feb 07, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
348 people viewed this question
Top Washing Machines Experts
