Question about Boating
The engine has been sitting for a year, I have
The engine has been sitting for a year I have checked the distributor cap the coil is new and I have the Resistors the spark plugs have spark there is compression and engine will start but will not remain running. If you choke it it dies if you leave it open and in idle it dies if you open the throttle it does not rev and dies. Any suggestions?
  • 2,926 Answers
I'm not sure what engine we are speaking of, but this problem sounds like it is fuel related, possibly dirt and build up inside the carburetor.
Posted on May 14, 2010
I have a 1999 Tahoe 8 cylinder I put in a new coil a whole new distributor distributor cap still it will not start
Pull the coil wire off the distributor cap. Put a ***** driver in it and place it close to any metal on the engine. crank over the engine. If you have spark, replace the pick up coil/ignition module in the distributor. If you have no spark. Check for power and ground at the coil plug with engine on. If it is there , replace the crank sensor.
Apr 18, 2016 | Cars & Trucks
ENGINE BACKFIRES, LURCHES AND WONT RUN WHEN HOT.
Need year make and model for assistance. Backfiring is usually caused by a lean condition ( not enough fuel ). Is the check engine light on? Have the codes been scanned? Why was the cap etc. replaced? Maintenence?
Jun 20, 2015 | Cars & Trucks
I had my 92 prelude started once i put a new battery in after sitting for 2 years. The next day it wouldnt start i have new dizzy new plugs new wires new coil and the icm and now it wont start. I have fire...
Check the inside of the distributor cap for "carbon tracks", which is a bad cap with a path to ground for the ignition pulse. You would need a new dist. cap and rotor, if you see those carbon tracks.
Feb 03, 2015 | Cars & Trucks
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
2000 chev pickup
Likely your coil, if you remove one spark plug and let it sit on the engine as someone turns the key you'll see if you have spark. My bet is that you don't and that your coil has gone bad or you have some other issue in getting spark such as a bad distributor cap or wire from coil to distributor cap. Iikely the coil has not been replaced in 20 years.. and it's failed. Cheap and easy to replace, typically just 3 wires.
Aug 04, 2012 | Tracrac 2000 Chevy S10 Pickup - 6 short...
Got kno spark from park plugs
You didn't state the year, make, model or engine. So I will guess it is a 4 cylinder car... late 80s or early 90s. If the coil is external ( not under the distributor cap ) You should check for spark from the coil to ground. If there is spark, that would mean there is spark going into the distributor but not coming out. That would indicate a bad distributor cap or rotor. If the coil is under the distributor cap, then you will have to remove the distributor cap. Inspect the underside of the distributor cap, look for burnt terminals, cracks or tracking. Next inspect the rotor, it requires removal of a screw through the side of the rotor into the distributor shaft. You might have to rotate the engine to access the screw. Beyond that there are three sensors and an ignitor in the distributor, some parts stores have the equiptment neccesary to test the ignitor. A new ignitor is around $80. If you have a multimeter, you can check for resistance to the three sensors at the 8 pin plug. The ohm reading should be 350-700 ohms across the blue/green wire and the blue/yellow wire, orange/blue wire and the white/blue wire, the solid orange wire and the solid white wire. None of the sensors are available to buy, so if any of these three sensors are bad, you have buy a distributor.. best of luck.
Mar 16, 2011 | Honda Accord Cars & Trucks
The engine has been sitting for a year, I have checked the distributor cap, the coil is new, and I have the Resistors, the spark plugs have spark, there is compression and engine will start but will not...
It sounds like a carburetor problem. If you send me the engine info, such as make, model, and year I can give more precise instructions on how to remove and rebuild or replace the carb. I hope this helps, please rate this, thank you
Mar 18, 2010 | Boating
I want to replace spark plugs (8) and wires on my '84 GMC pickup
get a 20 dollar haynes or chiltons manuel and find the module and coil. always change the ignition module and coil every 4 no more than -5 years to be safe.
Feb 10, 2010 | GMC Sierra 2500 Cars & Trucks
Coil pack
On all four cylinder sit on top of engine toward back, follow spark plug wire from top of valve cove to coil pack. On six cylinder engine the ignition coil sit inside the distributor under the cap where the spark plug wires go.
Jan 06, 2010 | 1998 Chrysler Sebring
1994 Civic DX coupe w/auto trans: engine quits after driving five minutes, with no warning, engine lights or anything. Let it sit for a few minutes, it starts up and drives like nothing happened. New fuel...
Honda had a recall on the distributor itself they dont cover them any more. they are bad about going out i think its just the pick up that goes bad but you have to replace has a unit
Nov 11, 2009 | 1994 Honda Civic
Boating Logo
56 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
