Question about JVC Car Audio & Video
Parking brake bypass
I have a jvc avx710 and i'm wondering if there is a parking brake bypass code for this unit or can you just ground the parkig brake wire?
The best solution and what i did was just plug the parking brake to the ground cable of the reciever...
And works perfect...
Posted on Aug 19, 2008
SOURCE:
My jvc kw-avx710 video is not playing... i looked at the trouble shooting and i found i need to connect the light wire to the parking brake. but i need to know what wire do i connect the light green wire...
You could just simply hook up a small switch so that the unit "sees" a constant ground. You will more than likely have to do some sort of combination in order for this to work. If you look in the manual, it should show you the correct combination. Instead of using the parking brake, you would use the switch. It might be possible to wire it directly to your ground wire. The thing to know with these methods is that you cannot drive around while watching.
Apr 14, 2011 | JVC Car Audio & Video
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
How do I bypass wiring up the parking brake wire
wire a switch pink to one end and the other to ground when you flip the switch the radio thinks its a brake.
Nov 25, 2009 | JVC KW-AVX810 Car DVD Player
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
Ground the handbrake wire to the outerpart of the "line out" connector if it's not in use, works a treat
Apr 29, 2008 | JVC KD-AVX11 Car DVD Player
Bypass parking brake
Does the suggestion by djBass work with the avx800 too?
Feb 16, 2008 | JVC KW-AVX800 CD Player
Dual xdvd 8281 how can you bypass parking brake on this new unit
I have one boss bv9970 how to bypass the parking brake in order to play the dvd
Jan 08, 2008 | Car Audio & Video
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Car Audio & Video Logo
1,747 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
