Question about Locks & Locksmithing
Removing ignition switch in 2004 Fleetwood Discovery
I am having trouble removing ignition switch in 2004 fleetwood discovery
  • 51 Answers
SOURCE: dometic 2008 fleetwood discovery...............Freezer side
Make sure the cooling fan on the back is working properly it should be running if the unit is on. While your there check to make sure the plug is still plugged in for the ac to work. Also check the breaker in the box reset if necesary. All this good on the ac the heating element would be my next choice.
Posted on Sep 08, 2008
  • 275 Answers
SOURCE: 2004 land rover discovery, ignition
it sounds like your starter motor is faulty. first make sure the battery is fully charged, then place a screwdriver between the contacts of the solenoid on the starter motor, if it again just clicks, then you need to repair or replace the starter motor.
hope this helps
Posted on Sep 11, 2009
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
cardenderek
  • 783 Answers
SOURCE: need a new auto shutoff
You need a new shutoff valve and need help locating one?? Just to clarify.
FiXYa Support
Posted on Aug 28, 2011
  • 192 Answers
SOURCE: Where is the hot water heater located in a 2006 Fleetwood Discovery 39L motorhome?
DIY RV Water Heater Maintenance and Repair
Check this video
Posted on Dec 03, 2015
Where can I find 99 Fleetwood discovery RV wiring diagram
You can get an owner's manual at the link. Not sure if they have wiring diagrams, but am sure they have contact information for the manufacturer.
RV Owners Manuals
Aug 18, 2017 | RVs
Where to add radiator fluid to a 2006 Fleetwood discovery 39s
into the overflow tank is the only place you can add fluid
Feb 06, 2017 | Cars & Trucks
Where are the house batteries on a 2002 Fleetwood Discovery motorhome?
they should be under steps as you walk in lift door
Nov 10, 2016 | RVs
Slide out blows fuses 2006 Discovery Bedroom slides
Does it move at all? Or does the circuit/ fuse ,pop as soon as you replace? Reset it?,,
has as any other work been done recently?, one last thing. Release the parking brake?, then replace the fuse, does it still pop?( the brake completes the circuit and allows current to the slide-out switch). In other words, if the fuse blows w the brake released? It gets me closer. Lastly?, how many slides do you have,? I own an old fleet wood,(1996), let me know, frank, 3143031728
May 16, 2016 | Fleetwood 2008 Discovery 39R
How do I remove frozen water pipes from underneath that go to fresh water tank?
thaw them out usually brought to a dealer they are hared to trace in the class A's
Jun 22, 2015 | Fleetwood 2008 Discovery 39R
How to adjust slideout on Fleetwood 39s discovery motor home it is draging floor when retracting
I cant understand your writing or wording,get a Haynes repair manual
Nov 24, 2014 | Cars & Trucks
Fleetwood wiring diagrams
Manufacturers do not publish wiring diagrams. The items that you have described will be controlled by a fuse located in the fuse panel next to the breakers. Next you would need to determine if you have power at the switches. From there you will need to check the connections at the fixtures and try to locate the point of failure.
Jul 25, 2014 | Fleetwood 2013 Discovery 40E
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
Locks & Locksmithing Logo
47 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
