Question about Delta & Single Handle Shower Faucet
Single-handle Glacier Bay shower faucet, hot/cold reversed
I just installed a Glacier Bay single-handled faucet for my shower. The markings show it starting with cold and rotating counter-clockwise to hot...only they are reversed. I rotated the cartridge 180 degrees and it still does the same thing. I am so confused. Please help! Thank you.
  • Randy Marshall May 14, 2010
    behind handle does it have a dail that can be adjusted it just move it maybe a 1/4 turn at a time it shouls be on cartridge?
  • 349 Answers
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
2 Suggested Answers
  • 10865 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Posted on Mar 18, 2010
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
My shower head comes on all the time
two possible causes. 1- make sure the valve body is installed with with shower mark on the valve body facing up. 2 - if you used pex pipe and fittings to stub out for the tub spout this will restrict the flow sending water to the shower, '' change out pex pipe and replace with copper or galvanized pipe
Apr 06, 2014 | Globe Union Glacier Bay 8 In Double Handle...
I recently had a Glacier Bay single handle shower faucet installed. The hot water is barely lukewarm. What is the problem?
Inside the handle assembly there is an adjustment for the anti-scald feature. If the installer left you the owners manual,it should have instructions how to adjust it. If not, have the installer come back to adjust it.
Jul 26, 2011 | Home
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Why is my hot water so low on pressure with a single handle faucet. Parts have been replaced yet pressure reduces to less than half when trying to get enough hot water to shower and rinse. Could this be...
Remove handle and adjust the rotational limit stop. As you move the rotational limit stop counter clockwise it will increase more hot water in the mix.
Remember where it is before starting and pull in back onto shaft out of place so you can move it a little and put back into place. It should have marks to line up to get you different setting's. Just put handle on and turn on and check for desired hot setting.
The only way to adjust this is to pull it out of place due to it fitting in place like a gear and reinsert and check water.
Jun 19, 2010 | Delta & Single Handle Shower Faucet
& Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
May 17, 2010 | Delta & Single Handle Shower Faucet
Mar 18, 2010 | Delta & Single Handle Shower Faucet
I have a delta shower faucet that I just repaired and wonder how to adjust a thing called the rotational limit stop?It says see instructional sheet which I don't have.
There is a round ring with teeth. This can be rotated clockwise or counter clockwise to adjust the tempered water temp. This step will have to be repeted until you get the temp that you want. Should be no more that 105 degrees max.
Mar 08, 2010 | Delta & Single Handle Shower Faucet
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Delta & Single Handle Shower Faucet  Logo
3,666 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
