Question about Sony PS-LX300USB Turntable
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
I have hooked up the sony turntable to laptop but no sound is working. All the connections and settings are correct.... What do I try next?
  • 4 Answers
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
Posted on May 14, 2010
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
My turntable is hooked but it wont work.
Bog standard TT connected to a bog standard receiver. Hmmm.
I cannot figure out where you have the equalizer placed (or why, but that is another topic).
What exactly is beeping?
Jan 24, 2013 | Sony PS-LX250H Turntable
I hooked up my new stanton t-60 turntable to an older sony amp that does not have a phono jack. i used a behringer pp400 preamp to connect the turntable to the amp. the sound is coming through with heavy...
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Jan 16, 2010 | Stanton STR8-60 Turntable
Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Sep 11, 2009 | Audio Players & Recorders
Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
May 06, 2009 | Audio Players & Recorders
Can't get sound from turntable to pc speakers
go to control panel, sound audio devices, hardware , USB Audio Device Properies, Properties, click the + next to Audio Devices USB Audio Device Properties, make sure that is highlighted, click do not map through this device, apply restart program. Under device properties make sure sound playback is set to default driver ie: Realteck Ac97 audio etc... Hope this helps
Dec 30, 2008 | Sony PS-LX300USB Turntable
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Turntable Issues
Check to make sure that your voltage setting is set correctly. Look under the turntable platter. You'll see a voltage selector. Make sure it's properly set for your area (115V or 220V).
If this does not solve the problem, or you have a turntable that does not have the voltage setting feature, then you might have a faulty turntable drive issue or an issue with the power, which means something is wrong on the main board (located underneath the turntable platter).
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 17, 2008 | Technics SL-1200MK2 Turntable
Power Issues or Drive Issues??
First and foremost, check to see that your turntable is set to the correct voltage setting for your area.
Remove your slipmat, as well as any rubber mat you might have on the unit. You want to expose the metal turntable platter. On the platter you'll see 2 holes on opposite ends. Rotate the platter to the 9 o'clock position. You'll see a voltage switch - 115V / 220V - make sure it's set to your country's setting:
U.S. / Japan / Canada: 110-115V
EUROPE: 220V
IF, you do not see this option on your turntable, then you do not have a Dual Voltage turntable. Now your talking about damage to the drive system. Which is comprised of various circuits, of which anyone of them could be bad. At this point, you'll have to take it to a reputable service center to have it diagnosed.
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 16, 2008 | Technics SL-1200MK2 Turntable
No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Sep 14, 2007 | Nakamichi AV-7 Receiver
Sony PS-LX300USB Turntable Logo
573 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
