Channels stops at 15
When we try program channels it dose not program as high as it should .
why?
  • 8,617 Answers
Do you have the antenna set to cable? Also some of the channels may be not added. Try to manually add each channel see if your able to do that.
Posted on Mar 29, 2008
Semi automatic espresso machine shot won't stop pouring
Continuous water flow indicates a stuck valve. These suggestions may help depending on type of machine:
Full Automatic (Super Automatic); Valve needs back flushing, cleaning, or replacement. There is an off chance the dose needs re-programing.
Semi-Automatic; Valve needs back flushing, cleaning, or replacement. Check programing for dose.
Manual; Most manual espresso machines require operator to stop dose. (By releasing dose button or lever)
Arm style Manual "Jaw Breaker"; These are physically chambered dose which are unable to constant dose. Bad seals needs replacement (if you can still find them)
final comment to this 'open' question; All coffee machines needs periodic cleaning. Most espresso machines needs back flushing (not to be confused with de-scaling.) Usually a cleaning tablet or powder is poured into dose chamber (or back flush portafilter) and cleaning cycle or long dose is performed. This cleaner will loosen baked in coffee and push it out the pressure relief pipe. The machine will need to go into a normal dose cycle without coffee to flush the cleaner out of the valve and dosing system. Do this several times. Good daily cleaning habits will keep your machine in top condition.
Sep 30, 2017 | Coffee Makers & Espresso Machines
Tip
Prevention of some types of cancer with vitamin D3 and iodine.
Vitamin D is not truly a vitamin. It actually is a hormone. Vitamin D3 builds up your immune system to fight off viruses and cancer. Iodine kills fungus, cancer and bacteria. Most people in the United States are deficient in both vitamin D and iodine. This just might explain the high cancer rates here. Keep the dose of vitamin D3 no higher than 2000 IU per day. Too much is not better for you. During the summer months, you can reduce the dose or completely stop taking it, if you get at least 15 minutes of sunshine every day.
on May 31, 2014 | Health & Beauty
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
May 07, 2012 | Televison & Video
It turns on but keeps beeping
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
Jul 15, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you program dose volume?
Keep press smoothly the ceter button stop for more than 10 sec. You will hear a sound and lights bliping.
now fill the filter with coffee and press the button you want to program and keep it press untill you will have the required dose in then cup.
Now the dose is set.
you can program all other buttons in the same way.
after you finish you can press once the stop buttong again. The machine is been programed and ready to be used.
You can reprogram any button you want again following the same prosedure.
Good luck.
Rememebr to vote for this answer.
Mar 20, 2010 | Espresso RMI La Cimbali Espresso Machine
Auto Scanning
Try unplugging it for 2 minutes then se what happens. Make sure that none of the buttons on the TV or remote contol are stuck (especialy if remote is near TV).
Feb 06, 2007 | Audiovox FP1510 15 in. LCD Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
