Question about Apple iPhone Smartphone
Tried to erase all data, iphone froze at the apple
Tried to erase all data iphone froze at the apple screen for 6 hours. Tried home and reset trick to no avail. What should i do?
    Sergeant:
  • 290 Answers
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
Posted on Jun 12, 2010
Tip
My Apple Iphone wont turn on. What to do when Iphone is freezing.
Hi.
What do I do if my Iphone does not start up anymore?
Here basic troubleshooting:
1 Try turning Iphone off, then back on. Turn it off by holding down the Sleep/Wakebutton until you see the red slider on display, then slide the finger across theslider. To turn iPhone back on, hold down theSleep/Wake button until the you see Apple logo on display.
2 Try pressing and holding the Home button for about ten seconds. This will close a frozen application or a stuck process. After this restart the iPhone following thesteps on point one.
3 If the above did not work, try doing a reset. Hold down the Sleep/Wake button and the Homebutton at the same time for about 10 seconds. You may see ared "power off" slider appearing on screen, then you see the display going black. Donot release Sleep/Wake and Home buttons until you see the Apple logo appearing on display. See picture below:
4 Reset all settings: Tap Settings>General>Reset> Reset All Settings. This will reset all settings to factory default. Data and media files will not be affected.
5 If that does not fix the problem, then try deleting all content and settings.
Tap Settings>General>Reset>Erase All Contents and Settings
This will delete all media and data. All settings will also be reset to default value.
6 Try restoring iPhone using the latest version of iTunes.
Connect iPhone to the computer using the data cable. When you see the IPhone in the Source list, click on Restore in the Summary tab.
If that did not work, repeat steps from 4 to 6 once more. If Iphone is still frozen, unplug it from pc, and try restarting the Iphone. Also reinstall Itunes and connect Iphone to pc again.
Ifrepeating the steps 4 to 6 did not fix your problem , then the Iphone isfaulty. In that case take it to a local Apple repair shop, or call Apple servicephone number listed on the user guide to arrange repair.
If the Iphone is faulty, sometimes reinstalling Firmware can fix it, but that, that is a risky procedure that will invalidate your warranty and damage the IPhone beyond repair. Better calling Apple before bricking the Iphone.
For this reason I will only post links on the argument.
On firmware update see:
How To Install IPhone Firmware
IPhone Firmware Download Links
Regards.
on Mar 22, 2010 | Apple iPhone Smartphone
How to master reset my Apple Iphone A1221?
Ok, I'm using my iphone 4 running 7.1.0 as my guide on this one, so I must not be using all the correct headings, but this should be close. Go to "settings->general->reset->Erase all content and settings". That should erase all personal data, contacts, songs, photos, etc... And reset all of the settings to factory default. If you think you may want to reverse this, or if you're planning on upgrading to a newer generation of iPhone and want to transfer your data then be sure you sync your phone with iTunes before doing this. Let me know if that does not work, there is another way to do it but it will require you to update to the latests version of iOS that your device can run, which will erase your jailbreak if you've installed one (not to be confused with re-lock your phone, if you paid to get your phone factory unlocked, and that does not mean a sim interposer, your phone should remain unlocked, no matter if you update iOS).
Jun 06, 2014 | Apple iPhone 3G
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 19, 2011 | Apple iPhone 3G
Dear, I tried to reset my Iphone to erase all the data and applications then it took 4 hours and it hung up to apple logo and i tried to reset it using pressing home and sleep buttons for ten second and...
Call your service provider .or apple or use their website or yahoo answers post your question you will be helped .
first call your tele company.take a look at the manual also
Aug 21, 2010 | Apple iPhone 3G
3gs iPhone froze at boot screen (apple logo)
Re-download the ipsw file that was on your iPhone, Download Spirit to jailbreak, and that should do the trick.
Jul 09, 2010 | Apple iPhone Smartphone
Tried to erase all data, iphone froze at the apple screen for 6 hours. tried home and reset trick to no avail. what should i do?
Ok, well plug it into the computer and will restore and update it erasing all info from the phone. What service provider are you going to use?
Mar 18, 2010 | Apple iPhone Smartphone
HELP !!!!
Here's what you should do: 1. Press and hold the Home button below the screen for at least six seconds, until the application you were using quits. 2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears. 3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. If it continues to freeze 1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted. 2. If that doesn't work, erase all content on iPhone. From the Home screen choose Settings > General > Reset > Erase All Content and Settings. All your preferences and other data are removed from iPhone. 3. If that doesn't work, restore the iPhone software.
Jul 01, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
79 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
