Question about Car Audio & Video
Speaker wiring i wanna no if you can wire a pair of dual voice coil 2 ohm kicker speakers at 1 ohm stable square ones kicker L5 SQUARE
  • Anonymous Dec 13, 2008
    how do i wire the s12 l5 kicker sola bar there 4 things on back of sub what goes where
Hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Posted on Mar 23, 2009
Your guys are bad solved my problem quickly i highly recommend your site
Posted on Mar 30, 2008
6ya staff
SOURCE:
How do you wire a single 15 L7
Depends on a few things. What is the impedance of your speaker? I will assume it is dual voice coil with each voice coil having a characteristic impedance of 4 ohms. Next what amp are you driving this speaker with? What is its minimum stable load it can run at in bridged mono? If it is 2 ohms stable then you can wire the voice coils in parallel, + to + and - to -. Then wire the + and - to the amp in its recommended bridged configuration. If the amp is not stable down to two ohms you will have to wire the voice coils in series, you will not have effective power from the amp with an 8 ohm load.
Here is a diagram from kicker to aid you.
http://www.kicker.com/dvc_wiring
Jul 20, 2011 | Kicker Car Audio & Video
How to wire up an audiobahn aw1251t i want to invert it
Two 4 ohm Dual Voice Coil (DVC) Speakers Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
have any more question let me know
http://www.tintingbyfredjohnson.com
Dec 23, 2010 | AudioBahn Car Audio & Video
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How do i wire two kicker l7 dual 2 ohm subs to play on a mtx 7801 class d amplifier
Hello moore_broder,
Your MTX 7801 is stable at 1 ohm, but you cannot wire a pair of DVC 2 ohm subs to that impedance. They can only be wired to 1/2 ohm which is too low or to 2 ohms.
Series the voice coils and parallel the subs. On each sub, jumper Black to Red/White Dot, then run both red's (positive) and both black/white dot's (negative) to your amp terminals.
The diagram is here.
Hope this helps.
Sep 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do you wire l5 to 2 ohm
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Sep 19, 2009 | Kicker Solo-Baric L5 Car Subwoofer
12" kicker l5
Series is +amp to +1, -1 to +2 , -2 to -amp . This way you have wired the two voice coils into one higher impedance voice coil.
Dec 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
280 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
