Question about Kenmore 64802 Top Freezer Refrigerator
Freezer and fridge not cooling. Light is on. Bpl frost free converti
5 Suggested Answers
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
  • 15 Answers
SOURCE: frost free fridge freezer freezing
make sure that the vents between the freezer and box are not frozen..check to see if the fan in the freezer is working(evaporator fan)..check timer and defrost heater,,
Posted on Aug 18, 2008
hiltonjug
  • 612 Answers
SOURCE: Freezer frosted Inside, Fridge not cool
You have a defrost problem. Most likley a defrost heater if it's a side by side. If you unload the freezer so that you can get to the inside back wall, take the screws out of the inside back wall. Remove the panel from the back wall. Take a hair dryer and melt the ice that has formed behind the panel. (DO NOT USE A SHARP OBJECT TO CHIP ICE OUT) You can then see the defrost heater. If you put it back together the refrig, will work correctly for around three days. If the heaters are glass, you will be able to see if they are broken or the filliment is broken inside. If so you will need new ones. You will need the make, model number and serial number. to buy the new part.
Posted on Aug 15, 2009
Testimonial: "thanks"
  • 670 Answers
SOURCE: Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Posted on Jul 14, 2010
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
Please give me some pictures of the temperature controller and defrost timer of the bpl fridge f 202...
GO ONLINE AND GOOGLE.WWW.TEMP/CONTROLLER AND DEFROST TIMER  PICTURES FOR BPL FRIDG F202
Oct 24, 2010 | LG Refrigerators
Ice building up at back of hotpoint frost free freezer. Also Red light keeps coming on. What is the remedy please ?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 20, 2010 | Refrigerators
Our top mount Kenmore fridge (Model # 253.77872509) is frosting up in the freezer section. Have turned off & defrosted the freezer on several occasions - it works for a few weeks but then begins...
Normally when frost build up occurs it's because warmer outside air is getting into the freezer and the moisture from that warm air cools and condensates then freezes into frost or ice. You either have a bad seal like the other listing states try leveling the front a little higher than the back. Or you may have an issue with the defrost heater, thermostat or timer. Do you have a light that comes on from time to time? If so you have an auto defrost unit. If there is no light you may not have a frost free freezer which means you will have to remove the frost manually.
Please check the bellow links for your knowledge:-
http://www.wikihow.com/Stop-Your-Fridge-from-Ice-Build-up
http://www.ehow.com/how_4781069_prevent-frost-build-up-freezer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore Refrigerators
Rtl100.bpl not found free
Hello Estherc54,
If you got rtl100.bpl error then there are chances that your computer has registry problems. To repair rtl100.bpl error you need to follow the steps below:
  • Step 1 - Choose a rtl100.bpl error repair tool,download and install rtl100.bpl error repair tool Scan for FREE.
  • Step 2 - Click the Scan Button.
  • Step 3 - then click the Fix Button and your done! It is very easy to repair rtl100.bpl error.
  • URL : http://www.fixerrorfast.com/ttfix-rtl100.bpl_error-zz0001
    Best tools : Regcure, Perfect Optimizer
    Regards,
    soul_srch007
    Dec 05, 2009 | Microsoft Windows XP Home Edition
    Freezer is working but the firdge part is not cooling.
    1. Checking/changing a common light switch
    2. Common frost free fridge parts learn "what" is called "what" before starting your repair
    3. Compressor won't run or it is "clicking' on and off
    4. Cleaning the condenser coils
    5. Can my fridge be moved on it's side?
    6. Defrost drain freezes and then overflows
    7. Freezer door pops open when I shut the fresh food door
    8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
    9. How refrigerators work
    10. How a common defrost cycle works
    11. How to change a common condenser fan motor
    12. How to reverse the refrigerator doors on your refrigerator
    13. Help for storing an appliance
    14. How to change a common Whirlpool evaporator fan motor
    15. How to install or remove common shelf supports
    16. How long can I store food in my frost free refrigerator freezer and how?
    17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
    18. I feel heat or warmth around my refrigerator doors...help!
    19. Important Disclaimer
    20. My fridge is running but not cold enough  - with Frost free repair information as well
    21. My refrigerator is leaking water inside the fridge
    22. My fridge is leaking onto the floor
    23. My fridge is freezing things
    24. My fridge makes a bang noise when it shuts off
    25. My Frost free fridge will not run at all
    26. My fridge is making   screeching/squeak noises
    27. My GE SxS fridge door has dropped and/or won't open or close properly
    28. My water dispenser has white flecks in the water...what's up?
    29. Mending a crack in the refrigerator liner
    30. New adaptive defrost information
    31. Ohm meter testing a start capacitor
    32. Odor complaints with your fridge
    33. Replace a door gasket on a refrigerator
    34. Sample wiring diagrams
    35. Stainless Steel Cleaning
    36. Some help for an Amana refrigerator fan motor that will not run
    37. Will my freezer or refrigerator work ok in my garage?
    38. Whirlpool built refrigerator defrost timer installation help
    39. Water line "Y" hose for icemaker broken helps
    Apr 01, 2009 | Samsung Refrigerators
    We have a bosch air flow fridge freezer
    It's stopped completely
    It's not cool
    Cooling is poor
    It's noisy
    It leaks
    The freezer compartment is icing up
    The food in the refrigerator freezes
    There's water dripping inside the refrigerator
    The refrigerator never cycles off
    The ice maker has a problem
    There's an ice- or water-dispensing problem
    Mar 14, 2009 | Bosch Refrigerators
    Frost free fridge/freezer - not cold in fridge
    The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
    Nov 27, 2008 | Freezers
    Freezer not working
    same problem but electronic temperture on in fridge but keeps flashing
    Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
    Kenmore 64802 Top Freezer Refrigerator Logo
    130 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    Jude24
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
