Question about Imperial ICV-1-H Turbo-Flow Electric Single Oven
Imperial 1cv-1 oven.pilot lites but main burner will not lite
2 Suggested Answers
  • 401 Answers
SOURCE: light pilot for oven
IF IT HAS A STANDING PIOLOT YOU SHOULD CHECK YOUR BOOK ON HOW TO LIGHT.IF YOU DONT HAVE A BOOK SOME IF THE IMPERIAL STOVES YOU HAVE TO HOLD IN THE TEMPERATURE KNOB IN THEN LIGHT IT. HOLD THE KNOB IN FOR A MINEUTE THEN IT SHOULD STAY ON.REMEMBER GAS IS DANGEROUSE,IF YOU SMELL IT YOU SHOULD STOP AND LET IT AIR OUT.GOOD LUCK BE SAFE
ERIC
Posted on Jan 21, 2010
Oven willnt lite ploit is lite
Safety device will not allow main burner to recieve gas. or problem with thermostat.
Mar 09, 2015 | Magic Chef Ovens
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 | Ovens
I want to light the pilot light for the oven
How old is the stove-- for most ovens these days have electric Glow Ignitors-
Are you sure yours has a gas pilot?
If so-- there has to be a way of pushing in a 'pilot' button, to get the gas to start,
and there has to be a hole or area you can get to the gas burner/pilot, with a match, at the time you are pushing in on the Pilot lite
Let us know what you find--
Mack B
Jan 20, 2011 | Ovens
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Hotpoint gas range model RGB508 pilot is lit but oven burner don
are we talking about the oven.if so and the ignitor lite's up,and look's as strong as it was,than you my have a BAD SAFTY VALVE.
Nov 26, 2009 | Ovens
Oven burner will not ignite
http://www.southbendnc.com/downloads/manuals/500SeriesManual_1188716.pdf
try this web site for operations manual.
Sounds as if the thermocouple may be bad. It is enough to keep pilot lite but not enough to open safety valve. Some of their ovens have a "Mercury Switch" instead of a thermocouple. Look behind the kick plate. It will have a white ceramic base and have 2 wires going to it. The end sits in the pilot same as thermocouple. If there is a pilot valve, make sure that once the pilot is lit, you turn it to "on" if the position is available. Lots of options on these ovens as they custom build alot for certain companys. Check this out and let me know.
May 22, 2009 | Southbend S560DD (Gas) Oven
Lang gas pizza oven.. Main burners won't lite!
Hello. It sounds like, from what you said, you have a new thermocouple. The device it is attached to, the pilot safety, could have a problem internally that allows gas to the pilot, but does not open the main part of the valve, or electrically has failed on the main coil. If you have a thermostat with wires on it, you can jumper the wires, to bypass it, temporarily please, if it comes on, you need a thermostat, if not, it is the valve most likely.
Hope that helps, and thank you.
Feb 18, 2009 | Bakers Pride FC-616 Gas Single Oven
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
Imperial ICV-1-H Turbo-Flow Electric Single Oven Logo
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
D. E. Hev
Are you an Imperial Oven Expert? Answer questions, earn points and help others
