Question about Maytag MDB9100A Dishwasher
Maytag dishwasher MDB9100A---tub refills after cycle completed
Our dishwasher will complete a cycle, the tub completely drained, and in a few hours I can come back and find the tub full of water. This started a few months ago with only happening occasionally. We checked filters and drainage system. Dishwasher will drain completely after a cycle and will also drain when I push the drain button on the front panel...the water just comes back later....any ideas???
  • hoef Mar 31, 2008
    And, when I ask for Mr Wiz to refund my 20bucks he chooses not to answer me....
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
Posted on Mar 30, 2008
Our Bosch dishwasher always has condensation after completing the cycle. Is there a reason for this?
I have noticed the same with our bosch dishwasher. Once the unit finishes washing, it sits there silently for about 1/2 hour and then exhausts the hot/moist air through the drain pump and illuminates the "clean" light. With the tub still hot, I open the door and prop it open a few inches with the top rack for a few hours. Since the tub is still very hot but open to the much cooler air, a lot of that condensation will leave the clean dishes. A few hours or even overnight should do the trick! It isn't a perfect system but beats having that coil heater in the bottom to warp all of your plasticware.
Aug 13, 2017 | Bosch Dishwashers
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
I have a Maytag MDB9100A leaving food particles
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
Draining Problems
Use about a cup of Muriatic Acid. Run it through the dishwasher ( Empty of Course) five times. Only use the acid on the first cycle.
Oct 20, 2009 | Maytag MDB9100A Dishwasher
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
Maytag DWC7602 drainage problem from tub bottom
OK. Try these steps.
-If hooked up to a food waste disposer, be sure the "knock out" is removed from the disposal inlet.
-Be sure the drain hose is ELEVATED at least 32" so water cannot siphon back in the tub.
-Check for a food obstruction in the drain or disposer.
-Check drain hose for a kink.
-Check your home's circuit breaker or fuse box.
-Check that the cycle is completed.
Hope this helps you!
Apr 22, 2009 | Maytag 24 in. DWC7602 Free-standing...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag MDB9100A Dishwasher Logo
203 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
