Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Spa emptying when pump stops
By reading your website, my problem is not having a check valve on my spa, thus all the water running back into the pool when the pump shuts off. My question is......does not having a check valve hurt my spa in any way?
I have a Hayward pool pump.
  • 990 Answers
Yes, if you have plaster it will get a ring around it. I live in Phoenix and with the sun and heat it will hurt the exposed plaster.
I don't know how old your pool is but many of the ck valves on the market today are serviceable. Meaning you can open them and replace the gut or clean it if that is all it needs. So if you replace it go for the extra it takes to get one of these as it will make the future a nice place if this happens again.
You probally have at least two of these on your system one on the suction side and one on the return, and one is as old as the other. So you might want to do both at the same time.
Posted on May 13, 2010
What setting do you put it on to drain the pool for plaster repair
There is usually a setting on the handle that says "Drain" but if not you can always use the Backwash setting to get all the water out of the pool or at least most of it.
Rod
US Parts Center
May 12, 2014 | Hayward SAND FILTER, PRO SERIES
My spa water level is low w pool off and slowly empties when using spa
make sure your check valve on the return side of the pump is still good replace if needed
Apr 15, 2013 | Hayward Pool Products Pool & Spa
Pump is running but not returning water to pool
If you have suction, you must have discharge. It is a law. Your water is going somewhere. Check for your water going to waste. Are you CERTAIN you have suction ? When I first read your question, I suspected a impeller with a spun out center. The motor runs but there is no pressure and no flow.
Let me know ...
Nov 26, 2012 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Hi! I have a Hayward Pro pool/spa system with Jandy valves and I'm trying to figure out how to switch them from pool to spa. Either I empty the spa or I'm heating the whole pool. Help please!
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Apr 23, 2010 | Hayward SAND FILTER, PRO SERIES
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Jul 15, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Hi the basket/strainer gets empty all the time and I'm scared that the pump will break any minute
check the water level in pool to make sure pump isnt running dry.check the o ring where the pump lid is and lubricate.check that the valves to the front of pump is in the propper location.
Jul 03, 2009 | Hayward 1hp Power Flo Matrix Above Ground...
My jacuzzi keeps emptying into the pool when the pump switches off and then refills from the pool when the pump comes on - do you know what the problem is?
I agree it sounds like a check valve. if the water in the pool matches the water level in the spa, or drains all the way (depending on how far the spa is raised) then it is the valve before the pump, but if it goes down to the jets (and not any further) then it is a check valve or valve on the retun side of the plumbing ( after heater or chlorinator).
Mar 13, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
