Question about VeriFone TRANZ 380 Transaction System (X2, 256K) (P03600173)
Using it with ooma phone service will not connect. cannot recognize dial tone
3 Suggested Answers
  • 24 Answers
SOURCE: No Dial Tone
You need to check your modem setting under control panel, there is a "wait for dialtone" option that you need to untick. Please let me know if this fixes the problem.
Posted on May 27, 2009
  • 3 Answers
SOURCE: Will a veriphone 3750 work with Digital phone
No, sorry, you will have communication problems on any digital or VOIP (voice over internet phone) lines. Analog phone providers is the only phone system that will take care of this problem.
Posted on Oct 29, 2009
All 4 hand units say "line in use" How do exit tis situation? hand units model KX-TGA410, baseunit KX-TGA131
A "Line in Use" message generally means that there is no dial tone detected. Assuming that all of the handsets are in Standby and any other phones are connected to that line are also on their hooks, then you need to determine why the base isn't getting a dial tone. This can be an inside or outside wiring problem.
I like to use an old wired telephone for testing since power isn't required to use the phone. You also need another RJ-11 telephone wire. Try connecting a new RJ-11 wire between the KX-TGA131 base and the phone jack. If there is a dial tone with the new cable, you had a bad cable. If not, try the alternate phone. If the test phone has a dial tone, then the KX-TGA131 has failed or has a power problem. If the phone is under warranty, contact Panasonic.
If neither phone has a dial tone, take your test phone to another jack connected to the same phone line (number), if available. If you have a dial tone here, then the problem is in the first jack or the wiring to the jack. You can try to repair the jack yourself. Remove the cover plate and look at the jack. If any wires are loose, reconnect them to their appropriate location. See http://www.lanshack.com/wire_phone_jack.aspx for the usual patterns. There are two types of telephone jacks, keystone and screw terminals. For the keystone type, you need a punch-down tool (available at many hardware stores in the electrical section) to put the wires back in place. Do not strip the individual conductors before using the punch down tool. For screw terminals, strip the wire before securing it under the screw.
If you do not have another jack or there is no dial tone at the second jack, find the incoming telephone service box. Open the box and check the wiring. If you find an RJ-11 jack, plug in your test phone and listen for a dial tone. If there is a dial tone, you have a wiring problem. Check the jacks as above. You may want to have someone else check the wiring in the walls if there are no broken/loose wires in the jacks. Your telephone company will usually offer the service for a fee.
If you can't test the phone line at the service box or there is no dial tone at the service box, contact your telephone company. They will test the service box and should repair outside issues for free. (Some providers are trying to avoid copper repairs.)
If you have DSL, you may need to check the line filter. This filter can disrupt the dial tone when it fails. If the filter is in the interior, you are responsible for the replacement. In my service area, the DSL filter was in the service box so my telephone company repaired it.
I hope this helps.
(I've had no line issues several times. Sometimes, it was the result of a contractor cutting through underground lines. With copper wire, rodents sometimes damaged those underground wires. Once it was simply an issue of a contractor who'd left one wire loose after upgrading the service.)
Aug 26, 2017 | Lands Phones
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
CS6482 model phone system; (1) base unit, (1) additional phone. Cordless phones are both showing "LIne In Use" but there is no dial tone and neither phone is "in use"
The "Line in Use" message often occurs when there is no dial tone. You'll need to identify where the dial tone problem is coming from. First, check that the base has power and try a new RJ-11 cable between the jack and the base. I like to use a old corded handset phone for additional testing. First plug in a different phone to the jack. Do you have a dial tone? If you do, then the CS6482 has failed.
If there is no dial tone, next try plugging the test phone into a different phone jack, if one is available. If there is a dial tone at another jack and a new cord didn't help at the first jack, then you have a wiring fault at the first jack. This could be in the jack itself or in the wiring to where the phone service comes in. You can fix the jack more easily. Remove the cover plate and determine the type of jack and look for a loose wire. If the wires are attached to screws, you remove the insulation from the end of the conductor and slide it under the appropriate screw. Then tighten the screw onto the wire. For keystone jacks, you'll need a push-down tool to press the wire back into place. The tool is sold in most hardware stores in the electrical aisle. Do not strip the wire before pushing it into place. See http://cablesupply.com/content/47-telephone-connections-and-rj11 to match the wire colors to the correct pin on the jack.
If you do not have a dial tone at another jack or do not have another phone jack in the house to test, find the service box. Open the box and check the connection type. If you find an RJ-11 jack, use your test phone to check for a dial tone. If there is no dial tone or it isn't an RJ-11 jack, contact your telephone company. They can test the phone line and will repair the wires for free if there is outside damage. If the problem is inside the walls, the telephone company will charge a fee to repair the issue. (This may be easier than finding a broken wire in the wall yourself.) Note: some telephone companies are trying to move residential units to newer fiber optic services and do not want to repair the copper wire to the door. This can cause problems with some security phone alerts.
I know at least twice we lost the dial tone on copper wiring after rodents chewed on the wires. That issue hasn't repeated since we were upgraded to fiber. However, during the upgrade, the installer dropped one of the RJ-11 lines behind the siding on the outside wall. Thus one phone was without a dial tone, we found the dangling wire and restored the phone service in seconds. We also lost the dial tone after contractors dug into the underground telephone service up the road from us. That was repaired quickly.
I hope this helps.
Aug 16, 2016 | Lands Phones
Dial out always busy
View topic - Fast Busy Signal when Calling out - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13773
May 15, 2012 - I'm out of town, but yesterday I tried calling a few numbers and alwaysgot the fast busy. Incoming calls were fine. I rebooted the telo and it still ... Can't Dial Out To Same Area Code
Feb 4, 2014
Can't dial out
Dec 3, 2011
Can't make calls, can't receive calls, but I have ...
Sep 13, 2011
cannot dial out and dial in
Nov 1, 2010
More results from www.ooma.com
Jan 26, 2016 | Cell Phones
Where do i look to see why machine isn't calling out to verify card
first check the phone line it self. take all phone lines out of the credit card machine, and unplug the power to machine. now take a telephone with a phone line attached and plug that into wall as if you were making a call on that phone. check for dial tone. if you have a dial tone, make a call. do you require a 8 or 9 to dial out? you terminal may not recognize that.
also if you do have dial tone do you use digital or analog phone lines? you need analog for terminals. if you have a fax line you can connect the terminal to fax via phone line. if this does not work contact phone co and ask what type of lines you have, you can also connect most terminals via Ethernet.
Jun 08, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
I have ooma but when I make calls I can hear them but they cant hear me
This does not seem to be an ooma issue try another handset phone. Otherwise, you can contact ooma directly through their website.
http://ooma.com/offer/index_E?cid=20&offer=TELO129&purchase_code=BRD-NOV&gclid=CPK48fGi6roCFWpk7Aod1VoAWQ
Sep 16, 2013 | Ooma VoIP Phone Device with No Monthly...
My Uniden TRU8885 will no longer give a dial tone or ring when called (I tried using my cell phone). All associated handsets are similarly afflicted. Cleaning peope were here today and must have pressed...
The TRU8885 has a Do Not Disturb feature which will disable the ring on the base and all handsets. To toggle this off, press and hold the DND button on the base. (The key is on the lower left of the keypad, next to the * key). The answering system will turn on when the DND feature is enabled, if it wasn't previously on.
However, this shouldn't disable the dial tone when you call out. I suggest that you check that the base has power. After that, you have to look for a wiring problem. The problem could be the phone, the RJ-11 cable between the base and the wall jack, a wire that is damaged in the wall, or an outside line problem.
First try a new RJ-11 cable; make sure not to use a wired handset cord. After that, I like to use an old corded phone that requires no power adapter to test the line. If the test phone gets a dial tone, then the TRU8885 base has a problem. If the test phone doesn't hear a dial tone, try plugging it into another jack on the phone line if possible. If there's no dial tone (or no other jack), find the incoming service box. If there is an RJ-11 plug in the box, check for a dial tone there.
If you have no dial tone at the service box or can't test the line at the box, contact your telephone company. Most companies will check the line and fix outside problems for free. If the problem is at the first jack, remove the cover plate and look for a loose wire. There are two styles of RJ-11 jacks. The screw terminal type require you to strip the wire and secure it under the correct screw. For the keystone jack type, you do not strip the wire. You use a punch-down tool (available at many hardware stores in the electrical section) to push the wire back into the correct section of the keystone. The little pins will puncture the insulation when the wire is properly inserted to make the connection. See http://www.lanshack.com/wire_phone_jack.aspx for the connection wiring connections. If you have an DSL filter inside your home, replace it if it is faulty. For any other inside wiring problem, you may want to let a professional find the wiring break in the walls. Your phone company will do this for a fee.
I hope this helps.
(I have had dial tone issues from several different causes. A single jack's wire was left disconnected after a service upgrade. Several outages were from damaged outside wiring either from mice chewing or a contractor digging through the wire. With a DSL line, the lightning strike damaged the filter and blocked all of the signals. Recently, a fiber-optic service card failed resulting in intermittent dial tone failures. Except for the first issue which I could fix myself, the local phone company or appropriate contractors fixed the issue for free. However, I don't live in an area where the phone company is trying to stop serving some wired phone customers.)
Dec 29, 2017 | Uniden TRU8885 Digital Answering Machine
HELP?Why Does my telephone say connecting?
Most cordless phones will say connecting when the handset is out of range, the base has no power or the base does not have a dial tone.
I start my tests at the base and make sure that another phone (preferably an old corded phone) gets a dial tone at that jack. Try a new phone cord to check if the cable is bad. Check if the power brick for the base is warm and that the outlet has power. For some phones, you can reset them by unplugging the base and removing the battery from the handset. Then reconnect the battery and plug in the base. Check if the handset and base can communicate (try the Find Handset option). If needed re-register the handset.
If the test phone doesn't get a dial tone, then you need to find where you have a wiring problem. Try the test phone at another phone jack. If there is still no dial tone, find the telephone service box (where the phone line comes in). If you have a fairly new service, you will find an RJ-11 jack in the box. Plug in your test phone and check for a dial tone. If you have no dial tone, contact your phone company. They will come and fix the line for free. (If you can't use an RJ-11 cord at the service box, your phone company will test this outside connection.)
If there is a dial tone at the service box or at one jack and not another, it's an inside wiring problem. Look at any open wires (perhaps in the basement) for obvious damage. Open the jack and check for loose wires. (There are two types of jacks - one wraps the wire around a screw, the other requires a punch down tool to secure the conductors in the keystone. The conductors should be connected to the terminals in the correct order. To see a picture of the terminal connections that are used, see http://www.lanshack.com/wire_phone_jack.aspx . The punchdown tool is available at many home improvement stores in the wiring aisle.)
If your test phone had dial tone at the original jack and resetting the phone by disconnecting the power did not help, then the phone needs service. If it is under warranty, contact V-tech. Otherwise, you may be better off replacing the unit. These phones are not meant to be user serviced.
I hope this helps.
(if you add a comment with the model, then I will check if I can provide more details in my solution.)
Sep 28, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
My phone show in use. Therefore I have no dial tone. I unpluged all phones and still no service.
Maybe your line is out of service, you can test it by connecting a standard wired phone to the line cord instead of your wireless phone base, if you have dial tone, the problem is at your wireless phone system, if there's no dial tone it could be a cable failure or in the central office, in this case you have to report it to the corresponding phone company.
Feb 26, 2011 | Uniden Lands Phones
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Televison & Video Logo
51 people viewed this question
Top VeriFone Televison & Video Experts
AliennoisE
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
