Question about Microwave Ovens
Scott Horton has another problem,our microwave has just stopped it is not to old ,there is no power at all but there is power at the power point.Do they have a fuse interally or can you suggest what i can try
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right if the microwave is completely dead then this usually happens when the fuse inside the microwave has blown. This happens due to power surge and/or a part inside the microwave makes this fuse to blow. Please do accept the solution if the issue is resolved or post a comment with complete model no# and manufacturers name for further assistance.
Thanks
Rylee
Posted on May 24, 2010
Lg lmlv2055sb just stopped working
6 years may be the point where the repair could cost more than a new unit----Call a local shop to see what it costs to look at the unit and if possible get a ballpark estimate---then weigh repair versus replacement.
Dec 03, 2012 | LG Microwave Ovens
Oven stopped heating; everything else seems to be working. i dont notice difference in sound when turned on model JVM1642BB 003 man date july 2000
The symptom that you have described sounds like the magnatron has failed, the microwave oven looks to be approx. over 9 years old, at that age and with a failed magnatron it is not cost effective to replace the part, it would be best to replace the microwave oven at this point. Good luck!
Nov 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Microwave was working fine. Suddenly stopped.
First thing to try is to check the power point.
If there is power there, but still no activity when you turn it on, no display no lights, it will need to be taken in for service. Sorry for the bad news but hopefully it's just the circuit breaker for your power point.
Apr 26, 2009 | General Electric Microwave Oven
Stopped working during microwave function
First unplug the unit.
The problem is most likely caused by the thermistor (thermal resistor) failing. This device is located at the outlet vent and will cut power if the unit over heat or catch fire. All microwaves have it. You can test it with an ohm meter. You can get a new one from an electronics store like Radio Shack.
You will have to remove the cover to get to it.
This unit may also have a fuse inside, I do not know if this is the one you changed, but you can look at it. You didn't give a model number so I could not point you to a diagram.
Mar 30, 2009 | Panasonic Microwave Ovens
Microwave stopped working, no more power in it
the dated microwave is beyond repair parts including the case - to find a microwave to fit the old case and vent hole would be impossible - a new microwave is fairly inexpensive and more feasible
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
