Question about Necchi 3101 Mechanical Sewing Machine
Zigzag issues I have a Necchi 3101FA/3102FB (per manual) and I am trying to use my zigzag feature for the first time. It is not making a continual zigzag pattern. It will zig and then do stitches that look like long straight stitches. Then do a couple of zigs and then the straight stuff again. I have tried to adjust both the top and bottom tension without much luck. Not sure what I am doing wrong.
  • Necchi Master
  • 1,388 Answers
Either you have the setting on a variation of ZZ which steps forward several stitches then one to the side (ZZ), so check that first.
If you are certain it is on the correct ZZ setting, and this is a recent purchase, phone the dealer tell them the issue and arrange to take it back for them to adjust, it is almost certainly ever so slightly out of timing.
www.bargainbox.com.au
Posted on Mar 30, 2008
SOURCE:
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
My sewing machine won't zigzag. I have the settings as per my guide book, but it is just sewing a straight stitch. What do I need to do?
Do you have the width set properly? If you have the length and tension right, but the width is too narrow, it won't zigzag. Make sure you have the width set at 1.5 or longer in order to really see the zigzag stitch.
Mar 05, 2015 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Where is the button hole machine dial on the Necchi sewing machine
try these 2 links for a manual, it should have the information in it you need. you can choose which place to buy the manual from.
Necchi 3101 FA 3102 FB Instruction Manual
Necchi 3101FA Parts
Jul 15, 2014 | Necchi 3101 Mechanical Sewing Machine
How to fix zigzag problem
Have you changed the needle and cleaned and oiled the machine per the instructions in the manual? Is the needle in correctly and fully up in the needle clamp?
Jan 07, 2014 | Singer 5050 Mechanical Sewing Machine
Necchi 542 stich selector jammed
remove arm cover and locate zigzag mechanism, clean lubricate and try gentle pressure, leave overnight, heat with hair drier, keep well lubricated with penetrating oil and be patient, try not to use too much force.
Necchi machines are built to very fine tolerances so need careful and regular maintenance
Dec 19, 2013 | Sewing Machines
Necchi 3101 Mechanical Sewing Machine Logo
170 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
