Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Raw fuel coming from muffler when i crank it it is a 16.5 hp kohler eng
    Scholar:
  • 108 Answers
Typically this is caused by a sticking float in the carburator. It's essentally flooding itself out. You can take apart float bowl and clean the carb. For the float specifically, remove the pin that hold the float on and then remove the needle valve below that. If you want to go all out and do it right, get yourself a carb rebuild kit. They are very inexpensive and easy to do yourself
Posted on May 14, 2010
My 1998crafsman mower wont fire it has a 16.5 Kohler pro ohv enging what's the problem
something close to this one ?
what work was done on it last
if the engine is cranking over
if no sign of life or smoke
either bad fuel or air filter needs a clean
coil /spark plug
or valves
May 06, 2016 | Garden
94 Lexus gs300 with 2jz-ge engine has gas in the oil.what can cause this?
Called flooding it Raw Fuel is getting down to the crank Lot,s of thing,s does the Light Come On Eng Light ?Does it Stall Lot,s ?Has it Had TUNE UP Lately ?these are the Question,s I Need to Know To Help Ya
Apr 08, 2015 | Lexus Cars & Trucks
Kohler 27hp eng pi pes getting red hot an muffler
Overheating can be caused by a weak fuel/air mixture. Check fuel lines and filter and carburettor.
Oct 11, 2014 | Garden
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
I have a husqvarna 137 E series chainsaw wont start.
Back to basics, drain the fuel in the tank and refill with fresh, make sure the ignition switch is on, check for a spark at the plug, does the plug get wet after cranking engine, remove the muffler and check for any piston damage through the exhaust port, let us know your findings.
Jan 07, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Kohler 15 hp electric start seized up
Sounds good to me. Must of got wet in the rain?Who knows. Marvel works good. You can even put a little in with your oil change. Try to breck it loose by hand if you can.
Nov 06, 2009 | Garden
LTX 1000 craftmans rider 18 hp ohv kohler back fires/gas coming
your intake vavle is stuck in the open position
remove plug and muffler squirt oil down cylinder hole and on the vavle and crank over several times to free up
Jul 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
212 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
